Thread: Egr Valve
    Regular Member rfc52's Avatar
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Trim : 1.9cdti sri 150
    Engine : diesel
    Default Egr Valve
    i have recently had a code read and it was my egr, thing is what kind of problems will i have with it?.
    I was driving to work this morning and i lost power in the car and the car and spanner light came on and it goes off, power came back to the car after a little bit just wondered if this is what would happen with egr blocked up?.
    cheers.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I notice you have a CDTi 150, you can get intermittent issues if your EGR is sticking which is causing spanner light to come on then go. It's probably full of crud and causing the valve to stick open/shut when it shouldn't be. They can be removed and cleaned, blanked or replaced - dependant on what you want to do.
    What mileage is on the car?
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Engine : diesel
    cheers dan, car is at 105k at the moment just been on the phone to ben at mas performance car is booked in for egr blank and remap tomorrow morning at 8.30am,so hopefully should sort things out.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by rfc52 View Post
    It will be worth physically blanking the EGR too, as it sounds yours is sticking so may well be not sealing properly.
    West
    Once the egr is blanked run some carb cleaner through the inlet & then go for a good blast
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Engine : diesel
    how would i go about doing that mate?
    Lancashire
    Trim : XP1
    Mileage : 66000
    If you mean blanking it, then you need to buy one of these http://www.ebay.co.uk/itm/EGR-blanki...item1c27e9f9bb and you fit it between the bottom of the EGR valve and the exhaust gas feed pipe. Ben may have some, he could sort it for you, but if not the ebay route and 15 mins fitting it is the best way.
    Jan 2013
    tyrone
    Hi there, my vectra had your symptoms, loss of power and EML on so yesterday i followed a brilliand step by step guide to cleaning the egr, andi had to steep it in cleaner the release it with the hammer and punch, i then worked at it for another hour and fitted it again and the car is just great and even better the EML went of on its own, so i pressume it has reset itself after its been fixed. Just type in egr cleaned properly in this site,, amazing. OH nad i know nothing about cars so this was easy.
    Aug 2012
    Stonehouse
    Vehicle : vectra
    Engine : diesel
    thanks mate yeah will mention it to ben see if it is something he could sort out.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
