Thread: Aerial
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    Default Aerial
    hello just a quick question does any one know if you can get the seal under the airel separate or do you have to buy a new airel??
    any prices would help if poss
    its of my 03 sri standard (not sat nav)
    as its leaking in through it (after all morning trying to find where is was coming from)
    cheers Steve
    Regular Member ion's Avatar
    walsall
    Where did the water appear mate if you don't mind me asking.
    A mate of mine has a vecb & where the spare wheel is & the carpet is soaked but there doesn't seem to be anything obvious
    I have been having a bit of bad luck with cars raining in the misses vec b was leaking in also turned out the wiper spindle on the boot was leaking in and filling the boot and also the sealant over the weld at the n/s top when the boot is open had a tiny hole in it as well took me ages to find it had the back of the car stripped out and kept the hose pipe flowing over the car
    hope that helps
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by ion View Post
    On my Wife's Cavalier, that was getting wet in the boot, found that the water was getting in around the grommet / boot where the harness is routed at the top. It was then running down underside of rear wing.
    Even though the grommet was sat into metal, it was leaking past it. Seemed to cure it with black flexible sealer.
    Might not be that, but worth a look.
    Nicking Ya Dinner.
    Cheap fix Steve, get some clear silicome bathroom sealant, and apply some around the hole in the roof, then reseat the arial base.
    was going to do this but all the rubber gasket is rotted/torn so it looks a right mess will have to price one up from the dealers tommorow
    Regular Member solorider's Avatar
    swindon
    im afraid the seal is not available as a seperate part,you have to buy a new aerial base
    anybody know how much????
    The one i got for Payney was about 26 quid...same as yours.. 03 Sri, non NAV..
    Just here!!!
    Yep that's right and quick fix it is too not bad really,one peice though i'm afraid....20 min job.04 by the way on a 53 Mark oops!!!!!Dong!!!
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. tv aerial
    By VEC-MAN in forum General Chat
    Last Post: 28th February 2010, 12:41
