Results 1 to 10 of 28
Thread: cdti owners
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    Default cdti owners
    Been reading up about people adding 2 stroke oil when they fill up. 200 ml . Apparently makes the engine run a lot smoother ,less smoke and slightly better mpg ? Has anybody here done this before. I'm willing to give it a go. Can't do no harm surely
    Sep 2012
    anglesey, uk
    Just been reading more. It's been proven that it does nothing but good for your diesel engine. Add 300 ml to a full tank. Benefits are supposedly better throttle response. Less smoke. Quieter engine. Better mpg. Helps with dpf too as the fuel is burned more efficiently reducing soot particles. Keeps everything lubricated as that's what sulpher used to do bit it's been dramatically reduced to keep thegreen heads happy
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    300ml of low-ash two-stroke in a full tank of diesel. You'll be amazed at the difference after as little as 100 miles
    Sep 2012
    anglesey, uk
    have you done it before ?? and what did you find. all the above ?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by tiimi View Post
    Done it regularly on my old 2.2 DTi with great results. Quiet, smooth, less smoke, better MPG.
    Started doing it on my current CDTi two tankful's ago, and again, good all round. Will continue to use it
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Seems interesting might try this on my next long run.
    Any idea how long the affects last once you've gone through the tank or is it with every tank?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I found that the effects last maybe two-three tankfuls after you stop using it.
    I used it every other fillup on my last car, and it had positive results.
    Sep 2012
    anglesey, uk
    how much was you adding to how much fuel ??
    Aug 2012
    Hartshorne
    Trim : SRI
    Sounding good think I got some 2 stroke at home
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The first two tanks I added 300ml to a full tank of diesel, then 300ml every second fill-up (full tank).
  1. 1.9 CDTI Owners
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 10:47
  2. CDTI Sri owners. 120 or 150??
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2009, 19:05
  3. +1 to the 1.9 CDTi SRi Owners
    By CHRISRi in forum Introduce yourself.
    Last Post: 4th August 2008, 07:33
  4. 150 CDTI Owners help
    By leeds vectra in forum Engine & Drivetrain
    Last Post: 3rd November 2006, 11:13
  5. FAO DTI/CDTi owners
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2006, 20:05
