Results 1 to 10 of 11
Thread: Electronic Stability Control - is it fitted?
    Regular Member Lockstock2012's Avatar
    Aug 2012
    Bristol
    Default Electronic Stability Control - is it fitted?
    Does anyone know whether my 58 plate CDTI 150 Auto SRi would be fitted with any form of Electronic Stability Control? The reason I ask is that I had a close call yesterday when another car pulled in front of me on a roundabout - I managed (somehow) to avoid the collision and miss the island, kerbs, signposts etc eventually getting control of the car back and continuing on my way - I just wondered whether I am a stunt driver or if the car has some electronic aids that helped me get the thing under control?
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    it will have abs as standard which is designed to allow you to manouvre the car under heavy breaking.
    if you had tc then it would flash up next to your abs warning light when you use it.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Facelift Vectras apart from some early production models no not have TC or ESP if they do not have a V6 engine or IDS or ESP fitted at the factory or retrofitted.
    All non-V6 pre-facelifts ( and some early non-V6 facelifts) on all engines except 1.8 petrol came with TC as standard but without ESP.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by john_k_sri View Post
    my dads 57 plate 1.9 1.6v has ESP fitted from factory it was a option when ordering
    Aug 2012
    Bristol
    Well I guess I'm a better driver than I thought! Thanks for the info guys - I've recently come into possession of Op-Com so when I figureout how to load that and read the cars brain I'll check to see if ESP and TC are present but as an ex Co car I suspect it's gonna be bog standard!
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    whats the part number on your ABS module and what else does it say on it?
    Aug 2012
    Bristol
    Do you mean the ABS pump behind the Battery Box?
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    yeah, the ABS pump has a module attached to it.. On the side of this are the numbers and info that indicates what type you have..
    Aug 2012
    Bristol
    Just had a peek in the dark (and rain) there is a yellow sticker on the module under the pump with some numbers/letters in black - will take a closer look but it doesn't say ESP or TC on it like some Pics I found on Google.
    Full Member RichM's Avatar
    St Clears, S Wales
    82 Post(s)
    Vehicle : Monaro
    Trim : VXR
    Engine : 6.0 LS2
    It'll have a switch on the dash if fitted that when pressed will produce a warning light on the dash.
  1. Can traction control be retro-fitted?
    By sleepy in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 16:04
  2. Vectra C With No Cruise Control Fitted!
    By cphaza in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2011, 21:24
  3. Electronic Diesel Control Unit
    By cybergen in forum Engine & Drivetrain
    Last Post: 5th May 2011, 18:32
  4. How to determine whether my car has ESP stability?
    By jw128 in forum Suspension, Wheels & Brakes
    Last Post: 4th August 2009, 18:44
  5. Electronic Climate Control
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 13:37
vectra c electric stability control have I got it
can traction or stability control be fitted to vectra c
VECTRA ELECTRONIC STABILITY  light is on
