Results 1 to 10 of 14
Thread: heating problem
    wigan
    confused heating problem
    hi can anyone solve my problem my vectra 2004 1.8 heats fine the problem is when im idle at lights or traffic jam the heater blows cold at proper temp when i drive open road it blows hot can any one please help.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Possible that the water pump is knackered. Start the engine and remove the header tank cap, see if you can see any coolant returning to the tank.
    wigan
    cheers das i was thinkin that because i only just had thermo changed i will look in the morn dose your water pump only work when you are driving and not idle.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    what mileage has the car done ?
    have you had a cambelt and waterpump change ?
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    No, it works all the time. Even from cold you should see water entering the coolant tank with the engine running, due to the water circulating via the bypass pipe. Its not uncommon for the fins to fall off the pump.
    wigan
    118000 yes cambelt changed at 109000 dont think pump was changed but had it checked at vauxhall last year because i had heating issues but i solved that with a back flush now it only blows hot air when driving.
    wigan
    cheers das hope its not pump had it checked last year it was ok but pumps are pumps.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    i would change the waterpump on that mileage if you dont know when it was changed
    ref this
    http://www.vectra-c.com/forum/showth...-1-8-Waterpump
    wigan
    yeah think i will then its done more bills
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    6 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    waterpump def in the early stages of going fubu, mine did exactly the same at fi, changed the stat, bled it and the BOOM overheated to about a million degrees (slight exageration)
  1. Heating and blower problem?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 26th February 2012, 17:07
  2. Heating problem
    By Bezz! in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2010, 16:39
  3. Heating Problem - Vec C 2.0 DTI
    By bidey89 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 12:38
  4. Problem with heating...
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 07:56
  5. 2.0 dti heating problem
    By jmacp in forum Bodywork & Interior
    Last Post: 23rd November 2008, 13:42
