Results 1 to 10 of 16
Thread: Clutch quiery
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    Exclamation Clutch quiery
    Hey guys,
    had a weird thing happen to me the other day, id popped to the shop the other day. upon returning to my car and trying to start it it made a sort of screeching grinding noise from the starter and then stalled, I reattempted starting and it started fine so didn't think much of it. i went to pull away and the biting point was really high and just after I got moving and went to go in to second the pedal just dropped to the floor so i pulled over and it popped back up and hasn't done anything like it since. i phoned the garage and they've said to just keep an eye on it and bring it back to them when im in the area again. the engine has seemed a little rattly when starting now and occasionally when im driving and i stop the revs can drop down to about 600/700 and then back up to 850 after a second. just curios as to whats going on. going to clean and lube my swirl bars today and just have a look about under the engine. i have also had my dmf replaced in the last week.
    any help would be greatly appreciated.
    Aug 2012
    Hartshorne
    Trim : SRI
    Anybody got any ideas?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    No idea what car you have as nothing mentioned about engine etc?
    But as you say the DMF has been replaced in the last two weeks - take it back.
    Clutch could need bleeding through, or slave / master cylinder may be failing.
    Aug 2012
    Hartshorne
    Trim : SRI
    Fair enough. My car is a 2001 150 Sri 1.9cdti they've said to just keep an eye on it. Have started to struggle getting it in to gear now :-/ and its grinding a little when the clutch is down sometimes
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by owen_999 View Post
    Defo take it back mate.. Did they change the clutch (4 pieces) when they did the DMF?
    Aug 2012
    Hartshorne
    Trim : SRI
    Only dmf. They tried to get me to pay for it even though I've only had the car 2 months and it has a years warranty. So they just did dmf.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Thats real bad practice from the garage.
    the labour time to strip down to change the DMF - madness not putting a clutch kit in...
    Unfortunatly now it sounds like they will have to!
    Aug 2012
    Hartshorne
    Trim : SRI
    Yh. They said to me it's worn but doesn't need doing. I asked if it was under warranty and they gave me the bull**** about wearing parts. But I didn't pay dealer prices to have a car for 2 months. So going to argue it out with them later this week. Unfortunately I'm 160 miles away working from the garage :-/
    Middlesex
    Trim : SRI
    Mileage : 100k
    See if they will settle on a figure. A clutch and DMF change is approx £800 all in for the job so see if they will contribute towards that from a garage local to you? Dunno....
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Quote Originally Posted by AntSSSS View Post
    How can it be bad practice the OP refused it?
    Clutch is a consumable. You should have had it changed but at the same time. My dealer replaced the DMF on my car under warranty and the clutch at the same time, but the labour was coverd as they were working in the same area so I only had to pay for the clutch itself.
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. Exhaust Quiery
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 21:15
  3. EGR / Inlet Quiery...... 2.2 DTi.
    By MJL in forum Engine & Drivetrain
    Last Post: 7th April 2010, 21:34
  4. Handbrake Quiery.
    By baz_rochdale in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 18:17
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
