Thread: Z20NET rattle?
    Jan 2006
    Dalriada
    Default Z20NET rattle?
    I started the car last night and heard a slight rattle from the engine, popped the bonnet and because it was dark and the engine was warm I didn't prod too much.
    I have heard it before and it disappears, so it's intermittent at best. My initial thought was chain, but I was under the impression the chain is most noisy when cold? So looking for an idea of where to start, or if anyone has had the same intermittent rattle? I am going to have a look around it tonight to see if anything is loose etc?
    Ideas?
    Sent from my iPhone 5 using Forum Runner
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I'd be looking at the Aux belt tensioner too. Try driving at low revs and pulling off, see if that brings it on.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    If it sounds like it's down the drivers side under the air box area, it's probably the pre-tensioner Steve. Mine did the same, sometimes you heard it on a cold start up, sometimes not.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    although this was on a warm engine, does it also do it when cold (you say you have heard it before), also do you get any extra vibration or a kick from the engine as it starts?
    Jan 2006
    Dalriada
    Cheers guys.
    Fil, been pricing up tensioners and will get one ordered ASAP to take that out the equation!
    Nige, can't really mind if I've heard it cold too, but no extra vibration/kick from the engine but it is more pronounced on the higher idle speed for the minute after start up?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Not many things that can cause a rattle on the Z20NET, I can only think of DMF, aux tensioner, timing chain or balance shaft chain that would really cause it. I guess hydraulic lifters might if they got blocked and worn, but not heard of that on these engines.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Quote Originally Posted by Steven View Post
    Ideas?
    Might want to re consider keeping it now Bawbag hee hee
    Jan 2006
    Dalriada
    Quote Originally Posted by Ian-Highlander View Post
    I'm thinking its maybe something loose rather than broken, but i will investigate..
    Quote Originally Posted by pogo View Post
    Maybe
    Jun 2009
    South Coast
    when was the last time you changed the oil?
    Jan 2006
    Dalriada
    Its due a change Nige, picking the stuff up on saturday am. It was changed the end of June. Recently had to top it up by about 1/3 of a litre which was unusual!
  1. z20net
    By sri-100 in forum Engine & Drivetrain
    Last Post: 6th November 2012, 22:05
  2. z20net
    By richy1974 in forum Engine & Drivetrain
    Last Post: 9th September 2012, 18:49
  3. chain rattle with z20net tensioner fitted.
    By mi-tots in forum Engine & Drivetrain
    Last Post: 30th August 2011, 12:39
  4. Z20net
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 09:56
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
z20net timing chain problem
z20net timing problem
