Thread: Broken my DT UK box.. ******!
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Broken my DT UK box.. ******!
    Driving along, noticed a lot of smoke when booting it.. spanner light.. followed by engine cutting out... my first thought is 'Oh bother, my cambelt has snapped' (Choice words).
    Open the bonnet & whip the engine cover off, straight away notice the tuning box has come unplugged from the common rail.. thank god!
    Push it back on, car starts fine. I clear the **** out of my boxers and carry on.
    I've just checked it & the bit that actually holds the connector onto the common rail has snapped, so it can just slide on & off.
    I've taped it on & its come off again once already due to the heat, the tape just melts.
    Is there any way to fix it? If I got a connector from the standard vectra loom & soldered it onto the wiring harness for the DT UK box, would this do the job?
    Cheers!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Speak to Andrew at dtuk for a new harness.
    scottish region
    As above
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    To solder the standard vx connector off scrappy is the cheapest way I think
    New DTUK harrness may be pricey
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    or use better tape.
    Regular Member coldo's Avatar
    Scotland
    Andrew will sort you out with a new cable but they wont be cheap.
    Have you tried cable ties? You should be able to efect a good seal using two or three of them.
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    use aluminium foil tape think that withstands high tempratures get it from tool station and such
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by grabos View Post
    That's what i'd be doing tbh
  1. Broken Down!!!
    By e55ex_rob in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2012, 18:35
  2. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  3. VXR Red Broken down on M1 J11
    By Impresss in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st July 2009, 19:45
  4. ECU broken need help!!!!!!
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st March 2009, 08:40
  5. No It's Not Broken Again
    By nutron in forum Trax 2008 - 7th September
    Last Post: 7th September 2008, 22:24
