Thread: heater issues not mine
    Jul 2011
    UK
    Year : 06
    Default heater issues not mine
    My mate's heaters when he turns ignition on there loud clicks mad it ao does it when he turns the temp rhwn work om all settings Speeds but it very weak not very powerful
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Re circ control
    remove passenger kick panel its a black box about size of pack of fags pink/ red rod atattached probably has tooth missing on cog
    Jul 2011
    UK
    Year : 06
    What would cause the low power
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Perhaps heater resistor fault.
    wouldn't be able to give you an easier answer on that one.
    check fuses an relays would be a start.
    See how much powers is actually getting their
    the speed is due to resistance so high resistance low fan speed low resistance high fan speed
    Jul 2011
    UK
    Year : 06
    Al have a look mate. The noise when he turns ignition on its quite a loud clucking sound as thou summit was stuck so that will be the 're circ
  1. Mine & Hers!
    By Mark The Cabby in forum Quick Photo Album
    Last Post: 1st April 2011, 00:07
  2. Heater Issues
    By greenz in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 14:36
  3. Irmi front bumper skirt...MINE MINE MINE
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2009, 22:07
  4. will this fit mine
    By SRimonkey in forum The 'Off Topic' room
    Last Post: 4th May 2009, 20:08
