Results 1 to 10 of 29
Thread: Intermittent heavy steering?!
    May 2012
    UK
    Default Intermittent heavy steering?!
    Hi all
    Unless I'm going mad my steering is getting heavy intermittently. It was fine today and then this evening definitely seemed to be heavier.
    When it does it it seems fairly consistently heavier, maybe slightly more so around the 12 o'clock position.
    I've checked the level, no leaks etc, no weird noises on lock etc. Does anyone have any idea what this might be?
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Try the steering when its heavy in the dark with lights on, if they dim/flash the pumps working so im not sure what else mate. Sure another member can help ya further tho.
    May 2012
    UK
    Quote Originally Posted by Beardy View Post
    Hi, thanks. Yeah I noticed it tonight actually, got the usual headlight flicker when turning onto my drive! I'm sure it's heavier though, very weird
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Yup its a strange 1 alrite mate, sorry i cant be anymore help to ya.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Check belt. Where alternator is at. Maybe new steering pump needed.
    Perth, Australia
    Do you have traction control? Does the dash light illuminate occasionally when it does go heavy?
    If so i would be looking at your CIM. Pain to replace (cheaper if you have a Tech2 and the know-how). Hopefully it doesn't come to this though!
    Check the usual suspects like tyre pressure, etc.
    Derby
    The power steering is electric and is susceptible to any drop in voltage caused by things such as slipping alternator belt etc. I had a weird fault on mine which turned out to be a wire i had connected to the feed side of the fuse that supplies the hydraulic pump that I had run to my towbar, the slight drop in voltage caused by the caravan fridge was messing up the pump while towing. Check all the connections and make sure your battery is in good nick before suspecting anything more sinister
    Dec 2012
    Ireland
    Sorry to hijack but same thing happened to me yeterday, Parked up the car but then had to pop down to the shops and when I tried to pull off it was like I had no power
    steering at all. Turned off the car and back on it was alright again.
    crook
    check fluid.....very rare
    resevoir is hidden behind drivers side wheel arch(between wheel arch and headlight)
    Derby
    I've had a few weird ones like this over the years, no computer display, no cruise control, engine str8 into limp mode. Switching off and on again always cures it, after all it is computer controlled. Do you have the means to check the battery voltage?
  1. Steering Intermittent sticking (Vectra C – 56)
    By Alhazard in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2012, 10:54
  2. Intermittent Power Steering problem
    By Marky P in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2011, 12:02
  3. Odd intermittent steering judder/wobble !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 23:34
  4. Intermittent Power Steering Failure
    By sol in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 16:15
  5. Intermittent steering wheel controls
    By Kryten2340 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2008, 15:57
auto electrics near tesco dragonsvile
Steering pulls and goes heavy intermittently
intermittent heavy steering
