Thread: Coolant running temp?
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Default Coolant running temp?
    Right just wondering if this is right 05 preface 1.8 petrol takes about 3 miles in the morning to get the temp gauge moving and it finally gets to about 88 by the time I get to work 5 miles total now it's a brand new genuine vx stat and housing there is hot air coming out the vents and I measured. The fluid that came out and measured the total that went back in after it was run up to temp and retoped back up and it was just over 2 litres I've been running it since 28 december with the new stat so I'm wondering if this engine is super efficient at keeping cool or I got a bum stat if any of you know the 2.2 petrol frontera it gets hot in no time at all and pron to boil up so I'm in wonder land at the moment I could understand if it was -5 when I set off in a morning but it's about +6 any ideas/conclusions?
    Oct 2012
    peterlee
    Sounds about right , i had stat replaced with aftermarket part , car wud run up to 80 c if lucky as soon as put heating on struggled to get above 78 .
    Replaced with genuine ( superceeded part) car runs 85-88 once warm , couple of miles and heaters warming up afterfive miles heat is hot .
    But not putting out same heat lecels as my mothers meriva , think it just a vectra oddity !
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Quote Originally Posted by mutley-k666 View Post
    your thermostat is ok
    i have a 1.8 04 2004 reg and it takes 3 miles to get to 86-89 in the morning and 6 degress outside and i have fitted a new thermostat when mine broke at 53000 miles
    Nov 2012
    Wakefield
    Just done mine too with an aftermarket stat and housing as posted in one of my previous threads ,mine sits bang on 90 after about 3 to 4 miles, I can't say every 1.8 engine will sit at the same temp but 85 to 90 should be fine.
    mines a facelift 06
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    My car is the same sits bang on 90 after a few miles and never budges (vvt engine)
  1. coolant temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2012, 23:18
  2. Coolant temp sensor
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 11:54
  3. v6 running temp?
    By urbanfox in forum Engine & Drivetrain
    Last Post: 19th March 2011, 19:43
  4. coolant running temperature?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:24
  5. CDTi running temp ?
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 27th February 2009, 15:01
