Results 1 to 10 of 23
Thread: 1.8 vvt (Z18XER) Thermostat Problems
    Regular Member sambuka's Avatar
    Oct 2012
    West Yorkshire
    Engine : 1.8 VVT
    Question 1.8 vvt (Z18XER) Thermostat Problems
    Basically drove the vectra around 25 miles the other day and the temp went up to operating temp (90*c).
    But then was on Motorway cruising around 70mph and the temp started to drop until it was not reading anything on temp gauge.
    When I arrived at my destination I turned ignition on and off and the temp returned to the operating temp of 90*c.
    Does this sound like a new Thermostat needed or could it be some other sensor?
    Many Thanks
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    This happened to mine--garage changed the complete unit--not cheap about £60 i think,but solved the same problem as you are having--always on around 90-92c now and nice and warm.Think there is another temp sensor on the engine--cheaper to start with-you can always try that first if you like--my money will be on thermostat unit--hope this helps-----Dave
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    As above the thermostat will need replacing
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    £34 for new thermostat housing with thermostat. quite easy to replace yourself. dont buy 2nd hand as the seal is once only set seal.
    Dec 2011
    Seaham
    Just bought one for £53.04 from Car Parts 4 Less and will be fitting it at the weekend, you need to make sure you get the right thermostat. I will strip the old housing and see if you can actually just change the thermostat inside?
    Oct 2012
    West Yorkshire
    Engine : 1.8 VVT
    Anyone with a link to the thermostat? The dealers are quoting £80 +vat Also when looking I seem to find 2 different part no: 24405922 and 55577072.
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Quote Originally Posted by sambuka View Post
    Both those numbers are correct (for the Z18XER). The 55577072 is now used in place of 24405922.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Many Thanks
    yes your thermostat has broken mine did the same
    the gauge would only rise when stuck in traffic
    as soon as i went on the motorway it flat lined to 70 degress
    its a common fault on vectra c
    just make sure you buy a gm one (original)
    (then when you have got a new one fitted) your fuel mpg will be better and hotter in the cabin
    the gauge will read 86-89 and stay there within 3 miles lets say with 8 degress reading outside (thats with the heater in the off position)
    a bit of info here below
    http://www.vectra-c.com/forum/showth...ter-temp-gauge
    vectra ste
    Oct 2012
    West Yorkshire
    Engine : 1.8 VVT
    Quote Originally Posted by Hue Jarse View Post
    Thanks for that I was thinking they were different units.
    Oct 2012
    West Yorkshire
    Engine : 1.8 VVT
    Quote Originally Posted by vectra ste View Post
    vectra ste
    Really appreciate your help. I've just been out in the car again and it got up to temperature perfectly fine and stayed at that temp. Is there anything else it could be as it seems to work correctly now.
  1. vec c 1.8 thermostat problems, symptoms?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 10:41
  2. Thermostat and other problems maybe? Advice please!
    By daz1409 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 22:48
  3. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  4. Z18XER Thermostat, Help!
    By Richie86 in forum Engine & Drivetrain
    Last Post: 13th February 2012, 20:34
  5. thermostat z18xer
    By shaun 37 in forum Engine & Drivetrain
    Last Post: 28th March 2011, 12:50
z18xer thermostat
vauxhall vectra thermostat problems
vauxhall insignia thermostat problems
z18xer thermostat housing
vectra c thermostat problems
z18 xer thermostat replacement
vectra c thermostat fault
insignia thermostat faultvectra 1.8 vvt sri thermostat code1.8xer thermostat replacementwhat temperature does thermostat open on vauxhall insignia 1.8vauxhall thermostat problemsinsignia car sri what can go wrong with electric thermostatvauxhall insignia thermostatvauxhall astra thermostat symptoms thermostat for vauxhall vectra c x18xer engineinsignia 1.8 thermostat locationvauxhall thermostat for z18xer vectra z18xer temperature sensorvectra 1.8 z18xer thermostatvectra c 1.8 vvt thermostat 105 is that rightinsignia 1.8 thermostatvectra c electrical thermostati need a vauxhall thermostat housing of a z18xer what cars will have onewhat the electric heater in the thermostat on the z18xer do
