Thread: What multimeter
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Default What multimeter
    Hello peeps , I'm looking at getting a multimeter but not sure what to get , seen really cheap ones and expensive ones.
    what should I get?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Something like this should do you. they make some high grade meters but they also do this cheaper range. I have one that i use regularly at work and it never fails me and always has the features i require
    http://www.ebay.co.uk/itm/UT61A-UNI-...item43af94da1a
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    158 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    In my view, you can't beat buying the best tools for the best you can afford while at the same time trying to sort out the cheap and nasty, last 5 minute stuff, from the professionally built, lasts a lifetime stuff.
    Using meters to measure and test electrics and electronics is a bit tougher to whittle down. I mean if all you are going to do is measure the voltage on a car battery, an alternator or a mains plug, you can buy much cheaper, but if you want a more versatile instrument then Wilkos recommendation is about the average minimum spend and should last you for ever if looked after.
    Unless you are doing in depth electrical fault finding on a regular basis when close coupling sensors and probes are useful (but you can think in terms of almost 5-10 times this price for starters), then this is probably a similar item to one I have in my own tool box.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Good one recommended above
    theirs some draper expert ones for about 15-20 quid and their reasonably ok I had one in my military tool box so I wasn't botherd ifit got bashed about etc
    Dec 2012
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Thanks very much. That's around the price I was thinking of. Don't want cheap nasty one.it will only be used for the basic stuff.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    If you only need it for basic testing then http://mobile.maplin.co.uk/module.aspx?moduleno=37279 will be more than sufficient it will have basic AC/dc and ohm's so it's all you'll need
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Here is another similar one, this also has auto power off after not being used for 15 minutes. Thats a feature i use often....
    http://www.ebay.co.uk/itm/New-Aidete...-/380437956199
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If you wanted to spend a but extra this ones an alright meter this is one I'm currently using every day and for the cash its good.
    http://item.mobileweb.ebay.co.uk/vie...w=140899351708
    Dec 2012
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Even though I will prob only use it for the basics, it would be nice to have one that can do a little more, incase I decide to take it a little further . You never know what problems might arise.
  1. Digital auto ranging multimeter Qs
    By SlowCoach in forum General Motoring Chat
    Last Post: 8th January 2013, 19:27
  2. MAF test results(multimeter)
    By justin32 in forum Engine & Drivetrain
    Last Post: 20th November 2011, 17:59
  3. Multimeter
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 21:03
  4. Multimeter setting for power drain?
    By rushy in forum The 'Off Topic' room
    Last Post: 6th March 2011, 15:12
  5. can anyone recommend a multimeter?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 13:38
