Thread: suspension overhaul
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default suspension overhaul
    Right going to do a full overhaul on my suspension. What do I need.
    Shocks front and back
    Drop links front and back
    Upper control arms back
    Arb bushes front and back
    Anything else I should add
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Top mounts (I think there called, big rubber bits you can see from under bonnet) lol
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Cheers lad. Anything else
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    What about ball joints/track rod ends or are they part of the arms?
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I had to change the rubber boot that covers the top of the front strut cos both of mine had split. I was told dealer only part. Cost about £30 iirc. Also fitted these http://www.ebay.co.uk/itm/SAAB-93-9-...item35c33d0978 cos my springs were making a twang/clunk as I drove.
    Aug 2011
    Bristol
    Steering arms if doing all.
    Bushes on control arms maybe front front/rear and rear. Front shock ball bearing.
    Rear stabilizer link/shackle.
    West
    Not one mention of springs lol...
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I'd echo the front strut top bearing comment, having just changed mine. The mounts didn't look too bad, but the bearings were totally shot after 100K
  1. 2.2. Direct h.p fuel pump.can i overhaul original.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd May 2012, 22:30
  2. Alloy wheel overhaul help
    By R2XPT in forum Detailing and Car Care Discussion
    Last Post: 16th August 2011, 18:47
  3. here we go! hassle after my overhaul.......
    By TimTay in forum Engine & Drivetrain
    Last Post: 15th August 2011, 12:03
  4. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  5. z22se engine overhaul
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 4th February 2010, 01:44
vectra c rear suspension overhaul
