Thread: Timing belt change on 1.9 CDTI 120?
    Sep 2012
    Doncaster
    Vehicle : Vectra CDTi (120)
    Trim : Exclusiv
    Mileage : 37768
    Default Timing belt change on 1.9 CDTI 120?
    When is the service interval for this changing please?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    The 150 is 100k or 10 years, not 100% sure if the 120 is the same, although 80k is much more sensible imo. Remember if it is needing done do not skip the water pump as that is what seizes and wrecks the belt in nearly all cases.
    Free bump.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    IMHO 70k - 80k, seen a few go with less than that tho
    Engine : 1.9 CDTi
    Was 10 years or 100k
    Then Vauxhall reduced it to 8 years or 80k due to failures before the old recomendation
    If it was me I would do 6 years or 60k
    BUT make sure you do the tensioners and water pump as these are what fail 9 times out of 10 and take the belt with them.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    No point in risking a wrecked engine. I do 50k / 5 years
  1. Replies: 29
    Last Post: 25th July 2012, 22:52
  2. Help :( low mpg after timing belt change
    By tipsy in forum Engine & Drivetrain
    Last Post: 12th May 2012, 19:02
  3. 1.9 CDTi 150 timing belt change
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2012, 20:15
  4. timing belt change
    By sri matt in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 18:25
  5. 1.9 cdti 120ps 8v cam/timing belt change ??
    By lollypop in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2009, 10:05
vauxhall vectra 1.9 cdti timing belt change intervals
vauxhall vectra 1800 cambelt change interval
vectra 1.9 cdti 120 cambelt change
vectra 1.9 120 cdti timing belt www.vectra-c.com
vauxhall vectra timing belt change intervals
vauxhall vectra 1.9cdti cambelt change interval
vectra cdti cambelt change
astra cdti 120 timing belt interval
Timing belt service interval Zafria 1.9 cdti
2008 vectra 1.9 cdti timing belt or chain
how to change cambelt Vauxhall 1.9 cdti
opel astra 1.9 cdti 2006 belt change interval
zafira 1.9 cdti timing belt change
zafira 1.9cdti timing belt change
vauxhall astra 1.9 cdti sri timing belt interval
vauxhall 1.9 cdti 8v water pump change
astra 1.9 cdti timing belt change
vauxhall vectra 1.9 cdti cambelt change intervals
Vauxhall zafira cdti 1.9 Sri 120 cam belt replacement intervals
vauxhall vectra 1.9cdti timing marks
removing belt on vectra 1.9cdti
08 plate astra cdti timing marks
vectra 19 cdti timing marks
