Thread: Heater matrix HAS a Massive leak
    Regular Member rubberduck*2012's Avatar
    Dec 2012
    stanhope
    Default Heater matrix HAS a Massive leak
    hi is it possible that anyone could give me step by step instruxtions on how to change the heater matrix in a 2.2 53 plate vectra
    regards stewart
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Rubberduck
    drain cooling system,remove coolant hoses to rear of engine on bulkhead they are quick release and turn anti clock,remove inner lower paneling at drivers side(5 bolts i think)remove centre lower panel(there is a hidden bolt you have to ease out the panel to access it)on the left were you remove side panel you will see the core cver remove the 3 bolts and cover,remove the fastening clamps and 2 heater coolant hoses and you have the core out, fitting is the same proceedure but make sure the quick release hoses click in you can here them lock in. good luck it's a fiddley job but needs patince!
    Jul 2009
    Engine : 20 Dti
    Dec 2012
    stanhope
    job sorted after removing all the dash the culprit is fixed i now have heating
  1. heater matrix
    By strothrc in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:31
  2. Heater matrix!
    By SUBEK in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 15:43
  3. replacing heater matrix
    By :LeeR in forum Engine & Drivetrain
    Last Post: 5th October 2011, 11:42
  4. Need help with the heater matrix on my vectra c
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th December 2010, 22:32
  5. Heater matrix now done
    By adfrodsham in forum Bodywork & Interior
    Last Post: 24th February 2010, 23:00
how do i know if my heater matrix is leaking vectra c
how to change the heater matrix on a vaxhall signum
