Thread: OSF driveshaft removal?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Question OSF driveshaft removal?
    I am trying to replace my OSF driveshaft (complete with ineer and outer CVs). I have it out of the hub etc but cannot get it out from where it joins the inner shaft which goes into the gearbox..
    Obviously the shaft on this side is a two piece job but how do i separate them..? Do I remove both parts right up to the gearbox?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No mate the inner cv pops out of the intermediate shaft in the same way it pops out of the diff on the passenger side. You won't loose any oil either
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Its out, I just moved the end of the shaft to a position in front of the wishbone instead of behind it. A whack with my hammer and it came straight out.. I tried everything when it was in he other position..
    So new driveshaft is now fitted.. just a shame the bearing won't come out of the hub.. Its Hammer time lol
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by Caveman_nige View Post
    just to clear up the some confusion here.. What i mean to say was hub would not come out the assembly/housing that its bolted into, I was referring to the bearing when i was meaning whole hub/bearing. You cannot separate the bearing from the hub to change them as far as i could see like you used to on older motors..
    Perth, Australia
    No, unfortunately it's a matter of replacing the whole hub assy and since it comes with the ABS sensor, the cost can be hefty.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    i know mate, did it yesterday... about 100 of our fine British pounds..
    ohh nice and shiney..
    Perth, Australia
    Very nice. I've actually just ordered a couple of complete drive shafts from J&R, super cheap compared to what dealers here want. Called up initially to get a quote for inner/outer CV's separately and they said around AU$500-600 EACH exGST! And a complete drive shaft - AU$1200 exGST. ****** crazy.
    J&R from eBay - AU$284 for TWO complete drive shafts, shipped!
    I think I need to replace my left hub as a local workshop overtightened a wheel bolt after an alignment and the bolt broke when I tried to take the wheel off one day, ruined the thread.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    thats a J&R you see in the pic above and below that fitted on my car.. 2 year warranty and damn good price..
    Perth, Australia
    Got a link for the hub assy?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
  1. driveshaft
    By tditony in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 12:39
  2. Front OS DriveShaft Removal
    By callist in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2010, 01:23
  3. Driveshaft for 2.2 Dti
    By damian s in forum Engine & Drivetrain
    Last Post: 20th February 2010, 18:35
  4. Driveshaft removal?
    By SYMON in forum Engine & Drivetrain
    Last Post: 7th November 2007, 13:31
vectra c driveshaft removal
how to remove vectra c driveshafts
vectra drive shaft removal
z18xe drive shaft removal
vectra driveshaft change
vectra c osf driveshaft
vectra c driveshaft rattling
o s drive shaft removal vauxhall
