Thread: Clutch judder
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default Clutch judder
    Does anyone else's vvt judder when in reverse or is it just mine i'm aware there was a problem on some models of this, Its also does it in first gear sometimes if pulling away up a hill well i say a judder its more noise than a judder like a knocking noise is the best way to describe it, Would a new clutch sort this problem out ? Thanks
    Barrow In Furness, Cumbria
    My VVT is ok.
    Have heard of the problem though and I think the cure is a new assembly.
    How many miles has it done?
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Had the same problem on my 06 plate. New clutch assembly fitted all engine and gearbox mountings checked, still the same.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Car has just ticked onto 78k today, its not stopping the car from driving just really annoying
    New Member Ems's Avatar
    Nov 2012
    Milton Keynes
    My 2004 1.8 energy does it, from reading about its a common problem with no cure. Mine only has 39,000 miles on it. Its a bit annoying and worse when its cold and/or damp.
    May 2012
    UK
    Very common when cold, doesn't get worse in my experience.
    Jan 2008
    west yorkshire
    Common fault with all VX 1800's. Loads of threads on here a couple of years ago. VX were replacing complete clutch assembly up to 18000 miles across the 1800 range. Used to be a common complaint, worse first thing in the morning. As I said I paid to have a new clutch fitted and it didn't make a bit of difference.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Just have to live with it then
    Dec 2011
    Seaham
    IS it actually a clutch judder or your tyres fighting fro grip? Especially if you have budget tyres on. Mine often has a bit of a bounce at the front if I try to pull away too fast in damp conditions.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Yeah mate it's clutch judder get the wheel spin on some roads around here when wet
  1. 1.8 clutch judder
    By tony in forum Engine & Drivetrain
    Last Post: 1st January 2012, 01:54
  2. Clutch judder
    By yessof in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2009, 17:10
  3. 1.8 vvt clutch judder
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2007, 19:43
  4. Clutch judder
    Last Post: 22nd July 2007, 09:18
  5. clutch judder
    By brian75 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 13:30
vauxhall vectra 1.8 clutch judder
vauxhall insignia 1.8 petrol juddering
vectra c clutch judder
vectra c 1.8 vvt clutch judder
vectra c clutch ju
vectra c knocking clutch in reverse
vectra c 1.8 vvt sri clutch judder
vauxhall vectra 1.8 clutch replacement now judders in reverse only
2008 vectra c 1.8 clutch judder
vauxhall zafira 1.8 judders in reverse
does vectra c clutch judder cause damage
clutch judder
vauxhall vectra clutch vibration
car judders when reversing vectra
vectra sri clutch juder
clutch judder 1.8 vauxhall vectra
07 vectra c clutch judder
vauxhall vectra c clutch judder
1.8 vectra c judder in gears
2005 vauxhall vectra 1.8 clutch
slight clutch judder vectra
clutch judder vectra c
vauxhall vectra clutch judder
car juddering in 1st gear vectra c
