Results 1 to 10 of 13
Thread: Intermitent Problem
    Jun 2009
    Glasgow
    Default Intermitent Problem
    Hello all and a happy new year! I have a problem with my 08 1.9 cdti. Every now and again my engine will run a little lumpy, it revs unevenly and I get alot of smoke from the exhaust and also from the back of the engine. I have recently cleaned out the EGR, Throttle body and replaced the fuel filter. After a couple of days it goes away and everything runs fine. Any help or ideas would be great. Thanks!!
    Sep 2010
    is it auto or an estate? - if so it may be the DPF doing a regen
    West
    Have you checked the swirl bar
    Jun 2009
    Glasgow
    Chewy, It's an estate. Dh no I've not checked that, I know it's in the inlet manifold is there a simple way to check it?
    Jun 2009
    Glasgow
    I should add the car dosn't get out on the Motorway for a good run very often.
    West
    Quote Originally Posted by Alphonsethegreat View Post
    remove engine cover look down towards the glow plugs, bar should be connected to the top of the 4 swirl pots & move when revs increase, have a search of the forum for swirl valves, lots of info
    Jun 2009
    Glasgow
    Cheers DH I'll have a look tonight!
    Sep 2010
    I'd also take her on a long run (20 mins with revs above 2k) - I feel the DPF is trying to clear
    Jun 2009
    Glasgow
    Cheers Chewy, I'll give that a bash!
    Jun 2009
    Glasgow
    Ok, so I checked the swirl bar and that is attached and is moving all the flaps when the revs are increased, gave it a little clean as there was an amount of Gunk around the right hand(as you look at the engine from the front) 2 swirl pots. Took it for a spin on the motorway and that seems to have cured to smoke issue and the up and down revs but......theres always a but. The engine still feels a little lumpy, there is a lack of pull below 2000 rpm and above 2000 rpm there is a loud whistle as you increase on the revs until you reach cruising speed.
    I'm going to put some carb cleaner through the throttle body inlet as many have had success with that on here.
    Any ideas on what or where I should be looking for the whistle?
    Thanks for your input so far!!!
  1. Intermitent low down power loss
    By bert3d in forum Engine & Drivetrain
    Last Post: 13th January 2012, 18:18
  2. 2.2 DTI intermitent problem..
    By peteh in forum Engine & Drivetrain
    Last Post: 29th September 2011, 08:28
  3. intermitent tickover problem
    By Arnie1 in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:37
  4. intermitent dash failure
    By pfloyd in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2009, 09:30
  5. speakers intermitent
    By surreyl31 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2007, 21:26
