Results 1 to 10 of 13
Thread: what brakes do i have
    redcar
    Default what brakes do i have
    I've started to get a scraping noise at really low speed so guessing It could be brake pads. It dosent happen at high speed or change tone when I brake but could it be anything else
    Which brakes are these I roughly measured them and they seemed bigger than the 314mm brakes. If they are the 314mm then what pads do I need
    THIS any help?
    redcar
    Yeah thanks, just need to know if these are 314mm. I measured about 325
    The outer front brake pads on the 314mm are very easy to view
    Equally, the nearside has a brake pad wear sensor
    Could you advise what engine your car has?
    There are no details in your profile
    scottish region
    Looks like 314s
    redcar
    It's a 1.9 cdti but there not standard and couldn't mind any info in paperwork as only had car 7 month
    redcar
    I think ill just risk getting the 314 pads, I can't think of what else the grinding noise could be
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    If those are 19's it looks like 314's the 345's fill the wheel up alot more. As for ure grinding noise take the wheel of and check them, the pads do touch the disc ever so slightly anyway so it might be that noise??
    Quote Originally Posted by jonny22 View Post
    Contact the VX Parts Department in advance, check that you can return them if they are indeed 345mm pads (most will exchange provided they are still in box and clearly not fitted)
    I've never had grinding noise, as the warning indicator usually switches on and I then watch the amount of brake pad left
    Eventually their performance is awful and I replace them
    However, I note in the photo there is a wear ring on the disc
    Mine has this when new pads are fitted, and have never found out why this occurs
    The dealership removed, cleaned and greased the pads but it made no difference
    It never appears on a set of new pads and discs
    redcar
    Its not so much a grinding noise more off a rubbing noise but can't see anything catching. There 18s on that picture. Are Vauxhall the best place to buy pads or eBay?
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
