Results 1 to 10 of 18
Thread: insignia washer issue
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default insignia washer issue
    Is there a way to adjust the flow? My passenger side washer seems to let more through than the drivers side. They're retrofit to a signum by the way.
    Sodding Typical on Sea
    There is a post somewhere on how to mod a bic pen top to adjust the jets, sorry I cannot locate it but try in the How2 section till I find it again
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Does that just change the direction though? It's the flowrate i'm looking to change. P.S. I found the how2 for the pen on a different forum
    Regular Member coldo's Avatar
    Scotland
    Mines has always done this... I just assumed it was one of those things.
    You can fit a none return vavle to the washers whcih may help this (comes standard on the insignia). I have them somewhere as I bought them when I got the jets...
    Time for some experimentation I think lol....
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I was thinking of putting a pipe in parallel of the first washer to see if it allowed the second washer a bit more pressure.
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    good idea that mate only maybe it would be better to take the single feed and split it on a Y one simply to one jet and a seperate one to the second jet and blank the end of the pasanger jet so it doesnt escape direct flow to each then isnt it
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah, well that was the only reason for the parallel. I'd need to blank the other end of the passenger side.... or buy another drivers side to replace it with?
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    You could crimp the passenger side hose slightly with a jubilee to reduce it's internal diameter and in theory the water should prefer the lower pressure route to the drivers side.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    The fluid flows through the passenger side washer to get to the drivers side though
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    I would.....
    T Piece into it prior to the passanger side then take a pipe to the drivers side, and see how that is, If that doesnt work, Leave it in place, and Crimp the passanger side, forcing the pressure to the drivers side.
    Also a none return valve could assist.
    hope the screen wash you got in is good :P
    Think ive got the pipe connectors here too if needed.
  1. insignia washer jets
    By brod999 in forum General Motoring Chat
    Last Post: 31st December 2012, 15:30
  2. Insignia Washer Jets
    By shane31 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2011, 18:15
  3. Issue with washer jets...
    By AndyMaz in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2011, 10:03
  4. Rear Screen Washer Issue
    By Kev_G in forum Bodywork & Interior
    Last Post: 21st March 2011, 00:39
  5. insignia washer jets..please tell me..
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 00:52
