Thread: Temporary boost gauge
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Temporary boost gauge
    Evening.
    Will be fitting a boost gauge to the car in the next week or so but only as a temporary thing to test some things out. Don't want a permanent install so I'm just going to pick up a mechanical one. Question is, what's the best way to connect it up and keep it removable? I've got a full silicone hose set on the car which is great (means I've got the odd spare hose) so if I was to drill a small hole in the old hose going to the throttle body, I could tap into there for boost and just replace it with my silicone one with no holes in when I'm done. What would be the best way of getting a connector in the pipe though? Not sure on that bit!
    Cheers.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Doesn't matter! Found this on the bay of E.
    http://www.ebay.co.uk/itm/Tdi-diesel...00382346324%26
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Thats what am using mate its spot on
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    150 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    If it's just for testing purposes, how about a OBD adapter and phone app, cheap scan tool or similar. Saves mucking about getting pipework from the engine bay to the interior.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Paul, what size hose did you use to connect it up? I've picked up a cheap Autogauge mechanical gauge but I can't find any info on what size hose it takes. I've got a few metres of 5mm vac hose kicking round but I'm sure that'll be too big. What did you use?
    Mr Teapot - thought about it but it wouldn't be quick enough. Will be looking for boost spikes etc.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    I used 3 mm mate was tight if i was gonna do it again i would use 4 and thats why i have mechanical to keep a eye on over boost and spike
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Ordered some 4mm. Cheers. Cable ties if necessary!
  1. boost gauge
    By Swedge in forum Engine & Drivetrain
    Last Post: 15th November 2012, 00:53
  2. boost gauge
    Last Post: 24th March 2012, 12:25
