Results 1 to 10 of 15
Thread: Digital auto ranging multimeter Qs
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Digital auto ranging multimeter Qs
    Ok, the instructions with this new item i got, is clap crap! (without swearing!) and basic information's crap. I'm trying to understand what each of those the dials points at means... ?
    New at this thing so hopefully will help others when they are clueless like i am! :-D
    I'm planning on testing each wirings to find why i get battery on dash light on 3-5 minutes after starting and driving. (no its not any starter motor/alternator/battery fault)
    Thanks in advance kind sirs :-)
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Dcv= direct current voltage ie what you want to be testing vehicle electrics with
    acv= alternating ie this is for mains electrics but can also be used on alternators and certain sensors
    Hz/ duty= is frequency and duty cycle so the amount of on signal a sensor is getting etc
    the last one is ohms this is for resistance checking sensors wiring etc. note the part needs to be isolate from power source before doing so.
    a better way to confirm circuit resistance is voltage drop
    I have a feeling you'll require a scope but you can do a lot of testing with a multimeter providing you no what the meter is telling you
    ie the voltage reading is just potential difference between the two points of where the leads are.
    i hope this is of some help
    feel free to pm me or ask question here if if may help others and ill do my best to explain
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Thanks man! You're kind to help with this... Which one to find earthing and how do i use this to test for like nearly broken wiring etc so i can test ranging to ensure its not breakage in wires if that makes sense?
    What i want to do is ...
    Find source of issue that causing battery light on dash to stop appearing!!! So testing wirings from alternator to end point check no breakage in wiring and test ground is good, starter motor same and battery with ground as well.
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Best way is voltage drop
    circuit has to be operating or trying to operate no volt drop if theirs no current flow
    type in voltage drop testing and their will be various demos on YouTube picture paints a thousands words and all that
    but basically test I would do would be batt voltage work to 2 decimal places
    then check voltage at the alt on both cables
    then red lead on batt pos and black lead on alt cable that'll tell you you positive side volt drop
    and then again neg to alt casing
    you can then narrow it down by moving the probe position along various parts of the circuit
    ill get laptop out tomorrow and see if I can do some paint diagrams to help.
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Just found a photo I sent to someone its basic testing of a charging system
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If theirs anyone on the forum that's relatively serious or some of the pro techs that do electrical diagnosis have a look a load pro leads
    videos on you tube by dan Sullivan
    awesome bit of kit and makes electrical diagnosis some much quicker
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Thanks mate, great help :-)
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Hi Adam, interesting diagram, but I have a couple of questions if you dont mind.
    What is the connection W and why is it connected to/across 2 of the windings??
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If I remember rightly its from older vehicles to drive the tachometer
    will pull my book out and check for you.
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Surely the circuit as drawn above couldn't possibly work with two of the stator coils shorted together, could it?
  1. What multimeter
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2013, 23:30
  2. MAF test results(multimeter)
    By justin32 in forum Engine & Drivetrain
    Last Post: 20th November 2011, 17:59
  3. Multimeter
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 21:03
  4. Multimeter setting for power drain?
    By rushy in forum The 'Off Topic' room
    Last Post: 6th March 2011, 15:12
  5. can anyone recommend a multimeter?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 13:38
