Thread: oil consumption
    Jan 2013
    Melbourne
    Default oil consumption
    2.2ltr CD Ecotech engine (australia) 60,000klm irregular use of oil rattly on cold startup, no smoke from exhaust, no leaks, otherwise performs well, is there a common/impending problem known?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I assume this is the 2.2 petrol engine with you being from Aus?
    It sounds like your timing chain is in need of replacement (common failing on the 2.2) How much oil is being used? It's not unusual for VX (holden) engines to us oil. Iirc the book states up to 1l per 1000km (i could be wrong)
    What grade of oil are you using?
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    timing chain tensioners were known to crap on from the factory, they advised the tensioner to be changed to the 2.0T (z20net) tensioner when the chain is done. I have read about people having issues with the chains in some form or another..
    what year is the car? is it the Z22SE or the Z22YH engine?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Jan 2013
    Melbourne
    Default Vectra CD oil use
    Thanks John
    2.2ltr petrol, oil usage has been inconsistent between oil changes worst case could be as you suggest 1ltr/1000km. (this has been rare and only happened a couple of times.
    the grade of oil used appears to be the answer,last oil change was Castrol Magnetec 10W 40 described by one retailer as crap,I have purchased Penrite 10W 40 full synthetic for next oil change will update this thread in a month.
    Jan 2013
    Melbourne
    Not sure the chain is an issue yet, but could be the source of rattly cold start after the several days parked, and also low oil level.
    Thanks for the heads up.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    That is chain rattel.... Just Cost mé 1800£ to fix....
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    You may have a very slight oil leak by the crank seal, very common once you get the miles on them... But yeah generally the engine does go through a bit of oil compared to other engines, especially on the correct rating...
  1. oil consumption
    By otto in forum Engine & Drivetrain
    Last Post: 3rd December 2017, 21:18
  2. CID & Avg Consumption?
    By Welsh_J_2000 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2012, 01:06
  3. Oil Consumption
    By johnnyallen in forum Engine & Drivetrain
    Last Post: 23rd June 2010, 21:31
  4. How much oil consumption is too much?
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 19:38
  5. 3.2 consumption
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 20:17
2008 astra 2.2ltr timing chain problems
2.2 direct oil consump
2.2ltr vectra oil leaks
