Results 1 to 10 of 28
Thread: When i wished i walked away
    New Member allymac's Avatar
    Sep 2012
    livingston,west lothian
    Default When i wished i walked away
    Hi there ,, have you ever bought something you wished you hadn,t,, bought a lovely cdti 150 sri, 05 , 2 month gone and replaced timing belt,w/pump, tensioners,, {230} 2 weeks later,, inlet manifold, 490,, now its an alternator,,, dont know how much this time,, anyone thinking of buying one ,, DONT,, AS THEY ARE CACK,, NEVER ENDING POCKET.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    All common problems.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    yep all common problems fella
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Just bad luck, some have very little problems some have lots.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    We do warn of the 1.9 issues. And yes a expolice omega pig of a car and the 4 cars i have had sense selling and rebuying the current car back.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    But at least its all fixed now
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    should ask about last timing belt change before you bought it and also other items are normal to be replaced on a veccy. i'm still on my 2nd inlet manifold at 250k, 3rd alternator and 4th timing belt kit
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    At least you know they been done so now should last you a good 100,000 miles or more if u're kind and gentle to ur car as if you would a new born baby :-)
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    i dont see the point in posts like these because these are thing that any buyer would check out.Ok the alternator can go without any warning(mine did) but they fail on any car at anytime.As for the cambelt,every car that has one needs it changing at some point so unless you didnt bother noticing the milage then its nobody's fault.Id also say the same for the inlet manafold,its a progressive thing that tends to happen over a period of time and the symptoms are well documented on various websites.There are a few ways you can fix them without having to have it replaced...i did the number plate fix and its been fine for about 10k now
    Have you thought about doint some of the fixes yourself? cambelt and alternator are easy and would save you a few hundred quid in labour
    Just seems to me you brought the car withought checking its history
    Rant over!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    few wear & tear items not the end of the world , granted its bad timing all at once but now the worst should be over .
  1. Ever wished you'd never started it
    By patch22 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2012, 21:28
  2. Look at one and walked away!!
    By digitalinkjetman in forum Insignia car chat
    Last Post: 24th August 2012, 20:46
  3. Forget Vectrauma somebody walked away from this!!!
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2007, 21:49
  4. Vauxhalls you wished you'd owned
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2006, 21:25
