Thread: Battery Light flicks on for a Moment when engine is switched off
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Battery Light flicks on for a Moment when engine is switched off
    As the title, what could be causing this to happen?
    Dave
    scottish region
    Weak cell on battery
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Battery is 6 weeks old
    scottish region
    Is it the correct battery for the car
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    It most certainly is
    Barrow In Furness, Cumbria
    Engine is noting a drop in voltage as the engine is turned off and revs drop.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by Chris SRi View Post
    Are you suggesting this is normal or is there an issue lurking?
    Dave
    I'd say it could well be normal. On some cars you get the battery and oil pressure lights flicking on briefly as you turn the engine off.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Cheers for that
  1. Replies: 17
    Last Post: 16th August 2012, 10:07
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. back end flicks out
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 16:19
  4. Hissing noise when engine switched off.....
    By s0501291 in forum Engine & Drivetrain
    Last Post: 26th April 2009, 01:17
  5. FR 1443: Engine - Vibration at idle with switched on A\C system (Vec C)
    By Duncan in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 25th June 2005, 16:48
