Thread: cdti stiff gear change, removing gear turret?
    Jan 2012
    Dublin
    Default cdti stiff gear change, removing gear turret?
    Ok so the stiff gear change on the 6 speed cdti box seems to be a pretty common problem. Ive bought the repair kit from ebay >> http://www.ebay.co.uk/itm/2609480933...84.m1439.l2649
    and watched the company's how 2 video
    http://www.youtube.com/watch?v=CFd_zp4f7GY
    I need to remove the gear turret to do the job. With the battery tray out is it a simple case of just locking the turret with a drill bit, pop the two linkages off, reverse switch and then undo the three torx bolts and lift the turret out? Does the turret just lift out of the gearbox and drop back in? Dont have to link it to anything or drop it in a certain way?
    Sep 2010
    Merseyside
    Make sure the car is in neutral undo the 3 torx bolts and it just lifts out, getting it back in is a bit more awkward because the base of the turret sits in a spigot. It is critical that the 4 selector forks are perfectly lined up when replacing the turret or you will wreck your gearbox when you start the car and try to select a gear.
    Regular Member rudeboy_29's Avatar
    Jul 2011
    Doncaster
    Engine : Z30dt
    Year : 55
    Mileage : 132k
    Default Help
    Quote Originally Posted by Edzx1100 View Post
    Ive got to the point of pulling the turret out of the gearbox, I've locked it off using an Allen key and as I pull it up it moves 1/2 an inch an dose not come any higher, I'm scared to force it and knacker inside of box any more advice on the matter would be brill thanks
    Northern Ireland
    Vehicle : 05 1.9cdti 120bhp
    Trim : Standard hatchback,VXR alloys.
    Engine : Z19DT
    Mileage : 97000
    Have you done the job yet Rudeboy. I'm having issues with mine and am considering replacing the bush in the turret. A friend tells me that you have to undo the gearbox mount to get the turret out.
    Regular Member FatboySteve's Avatar
    Bedfordshire
    Wiggle it a bit as you try to pull it up, doesn't require massive amounts of force, just maneuvering into a position where it can come out if that makes sense.
    This is from memory, I did it a few years back.
    Bedfordshire
    This sounds mad, but you can use a brake caliper slider bolt instead of the repair kit lol
  1. 1.9 cdti stiff gear lever and cant select gears
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 01:40
  2. Stiff gear change when cold - fluid changed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th December 2012, 14:58
  3. Stiff Gear Change
    By John Bishop in forum Engine & Drivetrain
    Last Post: 1st June 2012, 16:43
  4. Stiff Gear Change
    By sheddy in forum Engine & Drivetrain
    Last Post: 24th February 2012, 12:07
  5. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
vectra c turret
vectra c gear turret
vectra stiff gear change
vauxhall vectra c gearbox tower
zafira gear link removal
gears stiff vectra c
opel zafira gearbox
vectra c gear stick stiff
1.9 cdti gear turret
vectra c gearbox turret
how to remove selector turret f40
vectra c gear turret bearing
vectra c battery tray removal
vectra cdti stiff gears
vectra c gearbox turret upgrade
remove gearbox vauxhall vectra 1.9 cdti
vectra gears are stiff to select
how to change a vauxhall zafira sri 150 gear selector turret
https:www.vectra-c.comforumshowthread.php178888-cdti-stiff-gear-change-removing-gear-turret
vauxhall zafira stiff gear change
signum gearbox removal
zafira 1.9 cdti gear linkage replacement
nie moge zmieniac biegow vectra
stiff gearbox vauxhall signum
gear selector 1.9cdti
