Thread: dti aircon bracket
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default dti aircon bracket
    my AUX belt was loose so i thought it was the tensioner pulley so brought a new one. went to fit it today and i was wrong, the bottom of the bracket thats bolted to the engine and aircon has snapped. tried to remove the bracket today but got to drop the engine to get the pully off, wondered if anybody knows if this one is the correct bracket http://www.ebay.co.uk/itm/VAUXHALL-2...item51a6539fe0
    im sure i read on here some time back vx charge around £300 for this bracket
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Not the right one unfortunately, it's for the Vec B as it had a different belt layout setup on it.
    East Midlands
    Quote Originally Posted by chris1804 View Post
    Similar thing happened to mine a while back the actual bracket takes a lot of pressure not only from the aircon pump but from the belt and the tensioner its self...
    Here's a pic of the bracket lifted from my own thread back in march 11 when mine went,well the bolt sheared ended up buying i new bracket from the dealers £45 quid it was then.
    Yes the engine mounts need to be removed then the engine jacked up with a piece of wood on the sump to get clearance to remove the offending bracket,there are 3 nuts hidden away but you will find em...good luck.
    Oct 2009
    Sandwell
    Oct 2009
    Sandwell
    ill give vx a ring tomorrow then i thought the bracket was more than that.
    i done this about a year ago i had a snapped bolt in mine, when i drop the engine can the bracket be removed with the tensioner still attached?
    East Midlands
    No Chris because there isn't enough room to get the bracket and tensioner out.
    Oct 2009
    Sandwell
    sorted £36 from vx, was happy because i thought i saw on here they cost over £300
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. what car tax bracket
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 20:58
  3. Brodit Bracket
    By tyreman in forum Parts for sale
    Last Post: 29th March 2007, 20:00
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
aircon pump bracket vectra c removal
