Thread: Original xenon (AFL) flickers and sometimes blacks out
    Mar 2012
    Norway
    Default Original xenon (AFL) flickers and sometimes blacks out
    Hi all!
    First timer with xenons, so may be a silly question...
    My left xenon headlamp has begun flickering - sometimes almost unnoticeable (you can see it on a white wall at stillstand), other times it blacks all the way out, but it has always lit up again after a couple of seconds.
    I thought xenon bulbs had the tendency to "fade" out/over to purpel'ish color when burned out.
    What do you think it sounds like?
    1: loose connection?
    2: bulb faulty or burnt out?
    3: ballast faulty?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Try to swap ballasts between headlights if problem persist then bulbs but my guess will be ballast is on way out
    Mar 2012
    Norway
    If it is the ballast, is that considered as a wearing part?
    I still got a guarantee on the car, maybe I should try get them to fix that?
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Thomza View Post
    Ballast should be covered under warranty , try switching bulbs first if doesn't work let them sort it out
    Mar 2012
    Norway
    I will try that!
    Thank you!
  1. Replies: 2
    Last Post: 27th February 2011, 15:51
  2. Idiots guide to wiring in original Vauxhall Xenon headlights required please.
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2010, 18:29
  3. oil light flickers
    By luckyracer in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 17:19
  4. The alternative All Blacks rugby team
    By bigboynigs in forum Comedy & Humour
    Last Post: 19th October 2009, 23:06
  5. 215/35/19 instead of original 225/35/19
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 11:02
