Results 1 to 2 of 2
Thread: Vectra c air bag issue b1000 error code
    Jan 2013
    Westbury
    Default Vectra c air bag issue b1000 error code
    Hi all I am new to this but I would like to let u know that I drive a vectra c elegance 1.8 saloon and had a air bag light on I done some search regarding the matter and its a common fault mine had read b1000 error code replace airbag ecu cutting a long story short I done some digging around and if u get ahold of another ecu with the same part number on which you are removing it will work without resetting or reprogramming anybody needs any help just let me know and I will gladly help u in finding one
    Oct 2007
    nottingham
    yep did same with mine,except i blew 2 airbags as well replaced airbags ecu sensors, airbag light went straight out no problems bot like you say you do have to match numbers.
    tommy
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. Vectra SRi C alarm keeps going off code error fault
    By Tapie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2011, 20:53
  3. P1481 error code - can't fix on CDTI 120 Vectra C
    By Peter Nedergaard in forum Engine & Drivetrain
    Last Post: 11th November 2010, 12:39
  4. Replies: 6
    Last Post: 3rd September 2009, 16:40
vectra c had air bags go off replced them but cant reset fault code
b1000 vectra c
opel vectra c ошибка b1000
b1000 vectra airbag
b1000 airbag code opel
