Thread: CDTi Sri woes
    Jan 2013
    midlands
    Default CDTi Sri woes
    This is my first post, so hello everyone
    I've recently bought a cdti sri 150 pre-facelift, only I seem to have chosen one that has been collecting common faults off here like they were Nectar points
    It has an egr fault, a thermostat fault, a glowplug fault, an occasional turbo overboost fault, the cruise control is random at best and I have no idea when the cambelt was last changed
    Money is a bit tight, so obviously the first thing I have bought is a new set of headlights and a shiny grill (they did seem like a bargain though!)
    Anyway, now I've got that out of my system, I'm going to send her in to have the cambelt done, which leads me to a couple of questions...
    1, Should I get my mechanic to change the water pump when he does the belt change or not?
    2, Would it be cheaper to have a new thermostat fitted at the same time as the belt or not?
    3, Does the bumper have to come off on a belt change? (might be easier to get him to fit the headlights?)
    4, Can I use this stuff to clean the MAF sensor:
    http://www.amazon.co.uk/AF-Internati...7502131&sr=8-1
    5, How do you clean a MAF sensor?
    Thanks for any advice
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    1. yes
    2. yes
    3. no
    4+5 If i suspected that a maf was at fault i would replace it with a genuine part.
    East Ayrshire
    Trim : SRI XP1
    1. - You'd be incredibly stupid not to, just look at the other 2 posts on the subject today.
    2. - Yes, it's only 3 extras bolts to remove once the belt is off. If you left it til later and it was lucky enough to survive then you'd need to pay the full amount again.
    3. - Bumper doesn't come off for a belt change, but it's not a hard thing to do.
    4 + 5. - No idea, someone else will be along shortly to help
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    to vectra-c... if your planning on remapping the car just blank the EGR their a pain in the ars. you could try maf cleaner spray. are you sure you don't have a dirty map sensor too?
    Dec 2010
    Glasgow
    Mileage : Near 100K
    I think your getting a bit mixed up stevie16v a thermostat on a z19dth is on the other side of the engine
    East Ayrshire
    Trim : SRI XP1
    Ah, misread it, thought it was the water pump the OP had said. Cheers for the kick, I mean nudge
    Jan 2013
    midlands
    thanks for the quick replys
    ...so it will be cheaper to have the thermostat done at the sime time though, right?
    Would blanking the egr mean I wouldnt have to replace the dead one? (Have had it cleaned already, so Im sure its dead)
    I dont know if it has a dirty map sensor, although whatever and wherever it is, I'm guessing its as gunked up as everything else seems to be
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Yes, means you will only have to drain/refill the coolant once, less coolant lost, less labour time to bleed system etc etc.
    You will have to have the egr mapped out if you dont want an EML on the dash after being blanked, i have a fiat semi blanking plate to avoid the EML
  1. 2010 Insigina sri 2.0 CDTi sport tourer suspension woes...?
    By MCD in forum Insignia Chat (READ ONLY)
    Last Post: 1st June 2011, 14:43
  2. V6 CDTI SCV woes
    By averdigi in forum Engine & Drivetrain
    Last Post: 28th March 2011, 20:30
  3. 150 CDTi woes
    By Cannop in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 16:42
  4. More CDTI 150 woes!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 22:53
  5. More Woes
    By VauxVeteran in forum General Chat
    Last Post: 15th April 2008, 23:52
