Thread: confused now
    Apr 2009
    berkshire
    Unhappy confused now
    sorry to be a pain again but had misfire code read 0302 on 1.8 02 vectra c ,replaced plugs coil pack ,still runs lumpy no pull when attempting to move ,but now cant get any code reading at all now to see other codes if there is any ,does any one think it could be head gasket or am i overlooking something else thanks anyone p.s the orange engine symbol is on all time
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Im confused at all the threads your starting regarding the same problem ??
    Mar 2011
    Kent
    Hi alan66,
    I had the same problem last week with my V6. Same code, same symptons, etc,.. All indicating cylinder no.2 was playing up. I had the AA come out and double check it and he said the same. Turns out it was the middle out of the 3 front coil packs that had gone which I thought was the no.4 cylinder.
    Apr 2009
    berkshire
    but surely new one wouldnt be same as old ....could it
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Check inside is not clogged up.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    pm ed you keep us upto date
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Quote Originally Posted by C-Owner View Post
    Good helpful answer mate well done!
    May 2011
    South London
    Quote Originally Posted by pogo View Post
    http://www.vectra-c.com/forum/showth...79#post1958479
    http://www.vectra-c.com/forum/showth...26#post1959126
    http://www.vectra-c.com/forum/showth...7-confused-now
    Difficult to get continuity on the problem and not advise on things already tried if the threads are splattered everywhere.
    Just trying to get the OP some help faster.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If the eml is active their must be a code to be read
    mis fire on a single cylinder means its fault with that cylinder ie fuel, spark, compression
    if its a new genuine coil pack an plugs.
    check your spark gap again and your getting a spark
    compression test if ok
    test injector signal and if needs be swap injector with another cylinder
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Have you cleaned the throttle body
  1. Confused!!!
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 15:53
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
