Thread: Headlight Access
    Regular Member mjhayward's Avatar
    Oxon
    Default Headlight Access
    Hi
    Does anyone know if it's the case that the drivers side headlight unit needs to be removed to change bulbs on a 2006 2.0 T vectra?
    If so can anyone tell me how to do it!
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    Quote Originally Posted by mjhayward View Post
    Hi
    No you just need to remove the Airbox m8.... I changed all my lamps a few weeks ago
    Oxon
    Thanks a lot thought it was a bit much but thats what the manual said!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I just got scuffed knuckles and squeezed my hand in between the airbox and back of light with the aid of some pin nose pliers.
    Oxon
    This is probably a daft question too but how do you change the front indicator bulb, does the holder pull out ?? can't quite see how it's done and the manual doesn't tell you.
    Vehicle : SRi
    Mileage : 137000
    Its a twist bayonet style fitting.
    Oxon
  1. any-one with EPC access
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 14:38
