Thread: Should i buy this ?
    Dec 2012
    wolverhampton
    Default Should i buy this ?
    Thinking about getting this to sort out my condensation problem looks good with good reviews.
    http://www.amazon.co.uk/gp/aw/d/B009...7467038&sr=8-6
    Engine : 1.9 CDTi
    Its just a bag of silica gel.
    Can you not sort the problem why its steaming up?
    Dec 2012
    wolverhampton
    Well im going to check arial seal in abit but im looking at my car now and its all steamed up while rest of cars on my street are clear even a 15 year banger is dry what with that. Everythink seems dry in my car and its only 4 years old .... Its annoying
    Engine : 1.9 CDTi
    Have you checked the scuttle drains, the pollen filter, the rear lights and as you say the areal seal.
    Dec 2012
    wolverhampton
    Checked all above. Pollen filter is bone dry few leaves and little mud in there which has been cleared. Rear lights spare whell all dry. Arial seal seems to be ok tbh if i bend it toward the front it does lift up a little bit. If there is a leak there wouldnt it show on the interior roof cloth ?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Maybe the water is stuck in the doors? Check the bottom of the doors, there are drain points along them... could be blocked?
    ijk571
    Guest
    I have a similar one that turns pink when wet. It can be recharged in the microwave. It turns pink fairly often so it must be pulling moisture out of the cabin. My Vectra does not get used very much at the moment and it seems to keep it damp free, although it won't prevent the glass condensing overnight on a cold night etc.
