Results 1 to 10 of 17
Thread: What are Swirl Flaps?
    Oct 2010
    Lincoln
    Default What are Swirl Flaps?
    OK so I have the car going in on Tuesday to find out why the EML and Spanner lights come on randomly. AT the moment I get the spanner (centre dash) light on every morning after running for a few minutes, leave it and restart after a few more minutes and it's gone for the rest of the day.
    Just read the fault codes and get this -
    Identifier: 0x1001
    VIN: W0L0ZCF6871008116
    Hardware number:27539101
    Motor type: Z30DT
    Part Number:97353188
    Software version number: EC62M01S
    Programming Date: 20071207
    Hardware key number: H000005038
    System description: DENSO0100
    Type approval number: D06004
    Alpha code: BZ
    Hardware manufacturer system name: DECd2
    ECU variant coding: 0x0000B9D0
    Total number of fault codes: 6
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (12) - Not present
    P0235 - Boost Pressure Control Circuit Negative Deviation
    (12) - Not present
    P1110 - Swirl Flap Stuck Open (Bank 1)
    (62) - Present
    P1111 - Swirl Flap Stuck Closed (Bank 2)
    (63) - Not present
    P1900 - Diesel Particulate Filter Overloaded
    (55) - Not present
    (56) - Not present
    Once I have restarted, the P1110 goes to Not Present and the spanner goes out.
    Are the Swirl Flaps anything to do with the EGR?
    Engine : 1.9 CDTi
    If you search all sorts will come up showing the problem with the swirl flaps.
    They are on the inlet manifold under the black cover. They leak, stick or the bar falls off.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    info coming your way hold on
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by lee gsi View Post
    Oct 2010
    Lincoln
    This a Z30DT not a 1.9CDti so is it the same configuration? Nothing to with the EGR then?
    Engine : 1.9 CDTi
    Ah didnt notice the section its posted in.
    Will see what I can find on AutaData
    P1110 also comes up on the 3 litre when vacuum hoses are split as it reads different pressures so check them too.
    Oct 2010
    Lincoln
    OK reason for asking is that I had to call out the AA for a non starter. Turns out the starter motor is on it's way BUT he read the fault codes while he was there and reckons thay point to a failed EGR? I only had this replaced about 3 weeks ago!!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by lencuff View Post
    sorry i didnt see that
    whats your mileage on
    Oct 2010
    Lincoln
    104K miles but just had a major service and cam belt changed. And the EGR
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  3. Swirl flaps
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 19:13
  4. Swirl Flaps Pt 2
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 18:43
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
p1110 swirl flap stuck open
swirl flap stuck
