Thread: Fuel rail sensors at each end?
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Fuel rail sensors at each end?
    Z19dth, i was reading an old thread by the wizard on a problem he solved at the time by removing the sensors at each end of the fuel rail and giving them a clean, i know the one on the right(closest to battery) is the pressure sensor but what is the one on the left of the rail? Would it be beneficial to give them both a clean or is it a case of if its not broke dont fix it, just curious cheers
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If you don't have a problem don't go in their iIMO
    common rail runs on very fine tolerances an high pressures if you accidentally ingress any dirt you could have big problems.
    provided it runs ok builds and holds pressure just leave it be.
    Oct 2007
    estonia
    one is fuel pressure sensor and the other is fuel pressure regulator.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Thanks for the info chaps. :-)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by gaz51 View Post
    Later CDTI's don't have the latter.
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Quote Originally Posted by GazXPE View Post
    anybody know why they don't have it? Mine is leaking derv through it into into the harness connector and it is causing misfires and rough running..
    Can this be fixed? I guess the later issue fuel rail cannot be retro fitted to a 56 plate Z19DTH?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by Richard.roberts View Post
    Thats been a while back!, dont get here much with having the golf now aswell but keep having a read through now & again, vec stil going strong but still only got 85k on the clock so looks new!, hope you solved ur problem uve been searching so i guess you had one ?.
  1. Common Fuel Rail?
    By stakeknife in forum Y & Z30DT Specific
    Last Post: 25th February 2013, 21:30
  2. Z30DT Fuel Rail
    By mattoct in forum Y & Z30DT Specific
    Last Post: 21st September 2012, 10:53
  3. Z30DT Fuel Rail
    By mattoct in forum Engine & Drivetrain
    Last Post: 5th September 2012, 16:37
  4. EML with Fuel Rail Code ????? Help?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 22nd September 2011, 14:09
  5. Fuel rail regulator
    By rickyroo in forum Engine & Drivetrain
    Last Post: 31st December 2007, 10:52
vectra fuel rail sensors
