Found these on ebay, wonder if anyone has tried them from this seller.
The description sounds good.
http://www.ebay.co.uk/itm/2810384314...84.m1423.l2649
Hello Mate
They are way to expensive and will not do anything less or more that the error free 8 smd leds at almost a third of the price.
Where do you want to put them?
Chris
Hey Chris,
They are to be used as sidelights.
They are expensive than most the others, but there must a reason for them to be expensive. I just going on what the description says, i got these one currently http://www.ebay.co.uk/itm/3503728631...84.m1497.l2649. And they strobe with engine running, sidelights are turned off.
Ray.
Saw these a while back,but wasn't prepared to pay what they wanted as I don't believe the bit about them not flashing -strobing for one minute,the non strobing led on a canbus car is like the holy grale people have been searching for years but no ones ever found it
Doesn't matter what leds you find they will all strobe only way to stop that is wiring your sidelights up different and not off the light loom.
Thanks for the help everyone . I might go back to Mtec 501 coz they were quite good until one of them blown lol.
will these be the same as any of the others they all look identical to me whether there £2 or £10
http://www.ebay.co.uk/itm/2-x-ERROR-...item53f29fe8d6
also has anyone tried these in number plate or are they too bright?
I have 10 SMD LED's in the number plate lights and they are fine, so these should be fine too. You don't need canbus LED's in the number plate lights.
