Results 1 to 10 of 24
Thread: Boost Gauge fitted
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Boost Gauge fitted
    All working perfectly now, get 26psi on max boost.
    Jan 2006
    Dalriada
    Tidy mate. Did you wire the gauge to dim with the dash? Or is it fed from the cig lighter?
    Sent from my iPad using Forum Runner
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Very nice! Where did you get the gauge from?
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    That looks nice, wish I had a use for one .
    Sodding Typical on Sea
    Nice install
    Nov 2011
    Akrotiri, Cyprus
    Its wired to the cig lighter ignition live, a perm live behind the headlight controls and there was a wire to control the illumination which I put on a grey and yellow wire behind the headlight switch but it seems to be illuminated all the time at the same brightness lol. Might play around with the wires tomorrow but it works fine as it is. The needle does a sweep of the gauge when I tirn the ignition on which is cool. Might pop a vid on later of that!
    I got it from www.rspec.co.uk its the 52mm electrical blue led stepper boost gauge
    Jan 2013
    scotland
    26psi? wow thats alot of boost buddy my old impreza ran 14psi at 290bhp
    Nov 2011
    Akrotiri, Cyprus
    Yep mate, diesels run higher boost than petrol turbos normally. Mine defo wont be as fast as your old scooby lol
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Standard boost is 24psi overboost and 22pai sustained.
    I would not be asking that unit to sustain 26psi above 3000rpm.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    188 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Very pretty gauge, I love it. Is it air-fed, or does it use an electrical signal from the ECU or MAP sensor?
  1. Boost Gauge fitted
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2012, 17:20
  2. Boost gauge fitted..
    By Steven in forum Petrol Engine related
    Last Post: 22nd July 2011, 17:04
  3. Fitted Boost Gauge 2.0T
    By benholden2010 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 19:31
  4. VXR Boost Gauge Fitted....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 20:16
  5. Boost Gauge fitted
    By Jay Kay 313 in forum Styling
    Last Post: 12th September 2007, 22:23
