Thread: where is egr on 1.8 02 veccy
    Apr 2009
    berkshire
    Default where is egr on 1.8 02 veccy
    is there a how to on this too pls
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I'm assuming you have the Z18XE engine. Standing at the front of the car, it's on the right hand side of the engine as you are looking at it. Sort of to the side of the cylinder head, just above the gearbox. If you flip up the plastic battery cover you should be able to see it ok.
    The below pic was taken on my previous 1.8 '02 Vectra, looking from the passenger side onto the EGR. What are you looking to do to it, blank it, or clean it?
    Apr 2009
    berkshire
    cheers for that maybe going for fitting new ,or clean if its simple and poss
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I had trouble with mine, and a right good clean with carb cleaner and a stiff toothbrush certainly helped for a while. The car was struggling when cold, was spluttery and chuggy until it had driven a mile or two, then seemed pretty much okay. As soon as i cleaned the EGR the problem vanished. If you are going to take it off to either clean it or replace it, it might be worth popping into the dealers and getting a new gasket for it first. They are just a sort of thin metal plate with some form of coating on it, that gets sandwiched between the EGR and the manifold that it bolts down on to.
    Alternatively, you could just blank it off and forget about it. I believe Vauxhall deleted them from later 1.8s anyway. You can pick up blanking plates on ebay for a couple of quid. Think this is the right one, but check the exact shape if you fancy buying one:
    http://www.ebay.co.uk/itm/Vauxhall-E...item1c2e944800
    If you fit one of these, you can then just secure the EGR somewhere nearby and leave it connected, and that way you won't get any warning lights. I had one fitted to my old Vectra for a while after the EGR finally packed in, and seemed to work fine.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    I'm lucky I don't have one on mine, non vvti.
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by cliomjh 102 View Post
    Take it yours must be a slightly later model than the OP's? I think they were only fitted to the petrol 1.8 for a year or two, then they phased them out.
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Quote Originally Posted by puppet View Post
    Aye mine is a 04.
    Apr 2009
    berkshire
    hmmm will look into this first,just clutching straws really ,dont know if this causes my symptoms yet or if its one of many things
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Aye mine is a 04.
    That makes sense then.
    Quote Originally Posted by alan66 View Post
    Blanking plate would certainly be cheaper than a replacement EGR, that would be my thoughts.
    Apr 2009
    berkshire
    just elimenating things really cheapest first hopefully,the more i read the more things it could be
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  3. Veccy may have to go
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 22:51
  4. Veccy C to replace Veccy B?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 08:49
  5. V6 Veccy-B to Oil fired Veccy-C
    By Alpha10 in forum Introduce yourself.
    Last Post: 8th February 2006, 09:22
