Results 1 to 10 of 17
Thread: Waterpump failure, very lucky....
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Waterpump failure, very lucky....
    Ive got the z19dth in my saab 93, was out with wife and Kids in the car about 25 miles from home started to smell burning rubber through the air vents which was getting stronger and stronger, pulled up at the side of the road lifted bonnet and i could see burning rubber type smoke coming from behind the cambelt cover, straight away my heart sunk, anyway had the car recovered to my local mechanic who is saab/vauxhall specialist who now after replacing waterpump and new cambelt kit told me that the waterpump siezed which in turn started to melt the belt and one of the guide rollers and i was litterely minutes from disaster, i feel very lucky i turned the engine off when i did, my car is on 59k miles and wasnt going to do cambelt/waterpump until closer to 70k, my advice to anyone who is in doubt whether to fit new cambelt and water pump DO IT!
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Glad you got it sorted with no additional damage.
    Will be looking at getting mine done soon ... after the EGR Issues I got.
    Dave
    Carnoustie
    Good advice gives peace of mind
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by Sebastian B View Post
    Dave
    Yeh dave i feel i was very lucky, chris the mechanic said when he removed the cambelt cover the one guide roller was so disintegrated through the heat that the belt was hanging on by a thread, and if i even tried to start it once more would have been enough to throw the belt off eeek!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    we have recently had an insignia in at work with the same problem , 2009 sri cdti with under 15k on the clock .
    Sodding Typical on Sea
    Well done an excellent save!!!
    Regular Member wingi's Avatar
    Dec 2012
    clipstone
    just wondering if any one checked the coolant out before undertaking any work? ie what antifreeze protection did it show what tyre was it and the ph levels! i am wondering if this could be eliminated by correct servicing of the car? just a thought
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by wingi View Post
    I renewed the coolant about 3 months ago when i changed the thermostat but ive had the car 3 years its on an 05 plate so god knows when it was done before that if at all, so i think you got a valid point as to the life of the waterpump due to old coolant
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Seen this many times, and good save... Changed a few now that we're literally on there limit..
    coolant will not effect the life of the pump. The part of the pump that fails is the bearings and they are not exposed to the coolant at all for obvious reasons.
    A
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by Richard.roberts View Post
    as said before very good info there ive seen a few threads on here were the water pump seems to seize around this mileage taking the belt with it
    here is more info ive seen
    http://www.vectra-c.com/forum/showth...6v-CDTi-owners
  1. 1.8 Waterpump
    By Tinks in forum Engine & Drivetrain
    Last Post: 10th January 2013, 23:29
  2. thermostat or waterpump help please
    By mikecoz in forum Engine & Drivetrain
    Last Post: 29th October 2012, 18:26
  3. Waterpump
    By Tam80 in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 20:14
  4. waterpump failure?
    By toast in forum Engine & Drivetrain
    Last Post: 28th October 2010, 23:52
  5. waterpump
    By barry0101 in forum Engine & Drivetrain
    Last Post: 21st January 2010, 09:42
