Thread: Fuel Filter Removal
    winsford
    Default Fuel Filter Removal
    I had my 1.9 cdti 150 2008 in for a fuel filter change, he removed the pipe and power connector then tried to lift the can out of the cage and try as much as he did would not come out, he said i would have to go back as he would have to remove the cage from the body, is there an easier way to release it myself without going the removing the cage way.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    no need to remove the housing just take the long torque bolt out off the top of the housing slide the lid back and lift the old filter out of the cup , replace the seals and filter put the lid back on and tighten
    winsford
    mine doesn't have a long bolt at the top its a screw top can within the crash cage.
    East Ayrshire
    Trim : SRI XP1
    Theres a how to on here, or you can tap the lid off with a screwdriver but you need to be really careful
    winsford
    I have seen the how2 but doesn't mention how to remove a tight can from the cage and i don't really want to go the tap it with a screwdriver as i would probably damage it, would squirting something like WD 40 down the sides work
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Getting mine out was easy removing the pipe connections wasn't lol
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    mine just lifts straight out crash cage getting the top is a different story though lol
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Hand on the underside of the housing and pressure upwards and it will come. Some are tight. What ever you do make sure you remove it before trying to remove the lid!! Very easy to remove the lid with correct tool or filter wrench pliers.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    As said above, get your hand on the underside and push upwards. It might require some wiggle left and right as well. After removal, you can use the proper tool to unscrew the lid or hold it with your leg against wall and knock it round with wood and hammer to open the lid.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by peadar View Post
    That's for a 2.0 DTi IIRC. The CDTi is different.
  1. 1.9 CDi design (150 Fuel Filter Removal Tools
    By AdamNEUK in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2012, 10:58
  2. Fuel filter housing removal - 1.9CDTi
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 7th July 2012, 17:08
  3. CDTI Fuel filter removal tool
    By v33tra in forum Engine & Drivetrain
    Last Post: 8th February 2012, 22:34
  4. Fuel Filter removal
    By hefilump in forum Engine & Drivetrain
    Last Post: 21st July 2010, 23:00
  5. Fuel filter removal?
    By Ian T in forum Engine & Drivetrain
    Last Post: 2nd May 2008, 22:33
