Thread: Y22dth po340 camshaft position sensor malfunction
    Dec 2012
    Worthing
    Default Y22dth po340 camshaft position sensor malfunction
    Hi all,
    This will be my first post, also English is not my first language, so please correct me if/when I am wrong.
    Recently got P0340 error on Signum 2.2 DTI non starter. Have been looking around for a new pump(VP44 PSG16) and find out they they are quiet expensive (plus labour) and have to be reprogrammed after replacing. So decided to give it a go and try to replace this sensor in the pump myself. There is not much places where sensor can be bought and they are also not cheap. Older pump VP44 PSG5 using same sensor, just a bit different ribbon cable. Sourced one on local scrape yard from Focus TDDI(easiest to remove, pump just in front, inlet in rear).
    Scraped off lacquer and cleaned exposed wires, applied some solder on it and pulled them off from plastic (meant to leave them on it, but find it easier to solder later on). Done same from pump side but without peeling wires off plastic. (it it does makes sence)
    Matched length of cable, stick two ends together and just solder them one by one.
    In the end cleaned a bit around, between wires and excess of flus and solder. Tested connections from sensor up to pump connection, applied some super glue to strengthen new connection, then covered with layer of high temp. fuel resistant silicone. Fitted all back (cleaned inlet at the same time), then system bleed and car purrs happily again.
    I know it's not most elegant way to do that, but it worked (don't know for how long though) and saved me lot's of .
    Maybe someone will find this useful.
    Anyone have blocked EGR on those? any suggestions of where to blank it off?
    Thanks,
    Pavel
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Thats brilliant well done mate saves lits of pennys
    Dec 2012
    Worthing
    Forgot to mention about prices, I bought 2 sensors from scrapie (just in case), with some other plastics and couple of screws paid 15
    lincolnshire
    crickey , thats fab knowledge to have , ive made notes ! good job
    Dec 2012
    Worthing
    Here is list of cars with VP44 pump where sensor can be obtained, as posted before, easiest one is Focus, straight access to pump.
    Make Type Pump number Capacity Power kw Year Engine number
    AUDI A4 2.5 TDI 0 470 506 002 2.5 110 08/1997-06/2000 AFB
    AUDI A4 2.5 TDI Avant 0 470 506 002 2.5 110 11/1997-06/2000 AFB
    AUDI A4 2.5 TDI Avant quattro 0 470 506 002 2.5 110 11/1997-06/2000 AFB
    AUDI A4 2.5 TDI quattro 0 470 506 002 2.5 110 11/1997-06/2000 AFB
    AUDI A6 2.5 TDI 0 470 506 002 2.5 110 04/1997-05/2000 AFB
    AUDI A6 2.5 TDI Avant 0 470 506 002 2.5 110 02/1998-05/2000 AFB
    AUDI A6 2.5 TDI Avant quattro 0 470 506 002 2.5 110 02/1998-05/2000 AFB
    AUDI A6 2.5 TDI quattro 0 470 506 002 2.5 110 07/1997-05/2000 AFB
    AUDI A8 2.5 TDI 0 470 506 002 2.5 110 06/1997-04/2000 AFB
    AUDI A8 2.5 TDI quattro 0 470 506 002 2.5 110 06/1997-06/2000 AFB
    AUDI A4 2.5 TDI 0 470 506 006 2.5 110 07/1998- 10/2000 AKN
    AUDI A4 2.5 TDI Avant 0 470 506 006 2.5 110 08/1998-09/2001 AKN
    AUDI A4 2.5 TDI Avant quattro 0 470 506 006 2.5 110 07/1998-07/1999 AKN
    AUDI A4 2.5 TDI quattro 0 470 506 006 2.5 110 02/1999- 10/2000 AKN
    AUDI A6 2.5 TDI 0 470 506 006 2.5 110 11/1998-06/1999 AKN
    AUDI A6 2.5 TDI Avant 0 470 506 006 2.5 110 11/1998-04/2001 AKN
    AUDI A6 2.5 TDI Avant quattro 0 470 506 006 2.5 110 11/1998-06/1999 AKN
    AUDI A6 2.5 TDI quattro 0 470 506 006 2.5 110 11/1998-06/1999 AKN
    AUDI A8 2.5 TDI 0 470 506 006 2.5 110 11/1997-09/2002 AKN
    AUDI A8 2.5 TDI quattro 0 470 506 006 2.5 110 03/1998-04/1999 AKN
    AUDI A4 2.5 TDI 0 470 506 010 2.5 110 07/1998- 10/2000 AKN
    AUDI A4 2.5 TDI Avant 0 470 506 010 2.5 110 08/1998-09/2001 AKN
    AUDI A4 2.5 TDI Avant quattro 0 470 506 010 2.5 110 07/1998-07/1999 AKN
    AUDI A4 2.5 TDI quattro 0 470 506 010 2.5 110 02/1999- 10/2000 AKN
    AUDI A6 2.5 TDI 0 470 506 010 2.5 110 11/1998-06/1999 AKN
    AUDI A6 2.5 TDI Avant 0 470 506 010 2.5 110 11/1998-04/2001 AKN
    AUDI A6 2.5 TDI Avant quattro 0 470 506 010 2.5 110 11/1998-06/1999 AKN
    AUDI A6 2.5 TDI quattro 0 470 506 010 2.5 110 11/1998-06/1999 AKN
    AUDI A8 2.5 TDI 0 470 506 010 2.5 110 11/1997-09/2002 AKN
    AUDI A8 2.5 TDI quattro 0 470 506 010 2.5 110 03/1998-04/1999 AKN
    AUDI A6 2.5 TDI 0 470 506 016 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI Avant 0 470 506 016 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI AvantAII 0 470 506 016 2.5 132 05/2000 - 05/2003 AKE
    AUDI A6 2.5 TDI Avant quattro 0 470 506 016 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI quattro 0 470 506 016 2.5 132 10/1999-08/2003 AKE
    AUDI A8 2.5 TDI 0 470 506 016 2.5 132 05/2000 - 09/2002 AKE
    AUDI A8 2.5 TDI quattro 0 470 506 016 2.5 132 11/1999-09/2002 AKE
    AUDI A4 2.5 TDI 0 470 506 030 2.5 114 04/2001 -06/2002 AYM
    AUDI A4 2.5 TDI 0 470 506 030 2.5 120 07/2002 - 05/2003 BFC
    AUDI A4 2.5 TDI 0 470 506 030 2.5 120 06/2003-12/2004 BCZ
    AUDI A4 2.5 TDI Avant 0 470 506 030 2.5 114 09/2001 - 06/2002 AYM
    AUDI A4 2.5 TDI Avant 0 470 506 030 2.5 120 07/2002 - 05/2003 BFC
    AUDI A4 2.5 TDI Avant 0 470 506 030 2.5 120 06/2003-12/2004 BCZ
    AUDI A4 2.5 TDI Cabriolet 0 470 506 030 2.5 120 08/2002 - 05/2003 BFC
    AUDI A4 2.5 TDI Cabriolet 0 470 506 030 2.5 120 06/2003- 12/2005 BCZ
    AUDI A6 2.5 TDI 0 470 506 030 2.5 114 06/2001 - 06/2002 AYM
    AUDI A6 2.5 TDI 0 470 506 030 2.5 120 07/2002 - 05/2003 BFC
    AUDI A6 2.5 TDI 0 470 506 030 2.5 120 11/2002-05/2004 BCZ
    AUDI A6 2.5 TDI Avant 0 470 506 030 2.5 114 06/2001 - 06/2002 AYM
    AUDI A6 2.5 TDI Avant 0 470 506 030 2.5 120 07/2002 - 08/2003 BFC
    AUDI A6 2.5 TDI Avant 0 470 506 030 2.5 132 11/2002-01/2005 BCZ
    AUDI A6 2.5 TDI Avant Ali 0 470 506 030 2.5 120 06/2003 - 08/2005 BCZ
    AUDI A4 2.5 TDI 0 470 506 033 2.5 120 06/2003-12/2004 BCZ
    AUDI A4 2.5 TDI Avant 0 470 506 033 2.5 120 06/2003-12/2004 BCZ
    AUDI A4 2.5 TDI Avant qua 0 470 506 033 2.5 132 09/2001 - 05/2003 AKE
    AUDI A4 2.5 TDI Avant qua 0 470 506 033 2.5 132 11/2002-12/2004 BAU
    AUDI A4 2.5 TDI Cabriolet 0 470 506 033 2.5 120 06/2003 -12/2005 BCZ
    AUDI A4 2.5 TDI quattro 0 470 506 033 2.5 132 12/2000-05/2003 AKE
    AUDI A4 2.5 TDI quattro 0 470 506 033 2.5 132 11/2002-12/2004 BAU
    AUDI A6 2.5 TDI 0 470 506 033 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI 0 470 506 033 2.5 132 11/2002-05/2004 BAU
    AUDI A6 2.5 TDI Avant 0 470 506 033 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI Avant 0 470 506 033 2.5 132 11/2002-01/2005 BAU
    AUDI A6 2.5 TDI AvantAII 0 470 506 033 2.5 132 06/2003 - 08/2005 BAU
    AUDI A6 2.5 TDI Avant qua 0 470 506 033 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI Avant qua 0 470 506 033 2.5 132 02/2003 - 01/2005 BAU
    AUDI A6 2.5 TDI quattro 0 470 506 033 2.5 132 10/1999-08/2003 AKE
    AUDI A6 2.5 TDI quattro 0 470 506 033 2.5 132 02/2003 - 05/2004 BAU
    AUDI A4 2.5 TDI 0 470 506 037 2.5 120 06/2003 - 12/2004 BDG
    AUDI A4 2.5 TDI 0 470 506 037 2.5 120 11/2004-05/2006 BDG
    AUDI A4 2.5 TDI Avant 0 470 506 037 2.5 120 06/2003 -12/2004 BDG
    AUDI A4 2.5 TDI Avant 0 470 506 037 2.5 120 11/2004- BDG
    AUDI A4 2.5 TDI Cabriolet 0 470 506 037 2.5 120 06/2003 -12/2005 BDG
    AUDI A6 2.5 TDI 0 470 506 037 2.5 120 11/2002-05/2004 BDG
    AUDI A6 2.5 TDI Avant 0 470 506 037 2.5 132 11/2002-01/2005 BDG
    BMW 320 d E46 0 470 504 005 2 100 04/1998-09/2001 20 4D 1
    BMW 320 d Touring E46 0 470 504 005 2 100 04/1998-09/2001 20 4D 1
    BMW 320 d E46 0 470 504 020 2 100 04/1998 - 09/2001 20 4D 1
    BMW 320 d Touring E46 0 470 504 020 2 100 10/1999 - 09/2001 20 4D 1
    BMW 520 d E39 0 470 504 020 2 100 04/2000 - 07/2003 20 4D 1
    BMW 520 d Touring E39 0 470 504 020 2 100 04/2000 - 07/2003 20 4D 1
    BMW 318 d E46 0 470 504 025 2 85 09/2001 - 03/2003 20 4D 1
    BMW 318 d Touring E46 0 470 504 025 2 85 03/2002 - 03/2003 20 4D 1
    CHEVROLET Astra 2.0 GLS TD 16v 0 470 504 011 2 74 09/2000-01/2004 Y 20 DTH
    CHEVROLET Astra 2.0 GLS TD 16v 0 470 504 015 2 74 09/2000-01/2004 Y 20 DTH
    DODGE CUMMINS RAM 3500 0 470 506 027 5.9 160 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 027 5.9 172 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 119 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 142 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 160 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 172 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 187 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 029 5.9 205 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 021 5.9 180 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 022 5.9 172 05/1998-12/2002 ISB
    DODGE CUMMINS RAM 3500 0 470 506 028 5.9 180 05/1998-12/2002 ISB
    FORD Fiesta IV 1.8 TD 0 470 004 007 1.8 55 02/2000-12/2002 RTN
    FORD Fiesta IV 1.8 TD 0 470 004 007 1.8 55 02/2000-12/2002 RTP
    FORD Fiesta IV 1.8 TD 0 470 004 007 1.8 55 02/2000-12/2002 RTQ
    FORD Fiesta IV 1.8 TD Courier 0 470 004 007 1.8 55 02/2000-12/2002 RTN
    FORD Fiesta IV 1.8 TD Courier 0 470 004 007 1.8 55 02/2000-12/2002 RTP
    FORD Fiesta IV 1.8 TD Courier 0 470 004 007 1.8 55 02/2000 -12/2002 RTQ
    FORD Focus I 1.8 TDDi 0 470 004 007 1.8 55 01/1999-05/2005 BHDA
    FORD Focus I 1.8 TDDi 0 470 004 007 1.8 55 01/1999-05/2005 BHDB
    FORD Focus I 1.8 TDDi 0 470 004 007 1.8 66 01/1999-05/2005 C9D...
    FORD Focus I 1.8 TDDi 0 470 004 007 1.8 66 01/1999-05/2005 C9DA
    FORD Focus I 1.8 TDDi 0 470 004 007 1.8 66 01/1999-05/2005 C9DC
    FORD Focus I 1.8 TDDi Turbo 0 470 004 007 1.8 55 08/1999-05/2005 BHDA
    FORD Focus I 1.8 TDDi Turbo 0 470 004 007 1.8 55 08/1999-05/2005 BHDB
    FORD Focus I 1.8 TDDi Turbo 0 470 004 007 1.8 66 01/1999-05/2005 C9DA
    FORD Focus I 1.8 TDDi Turbo 0 470 004 007 1.8 66 01/1999-05/2005 C9DB
    FORD Focus I 1.8 TDDi Turbo 0 470 004 007 1.8 66 01/1999-05/2005 C9DC
    FORD Focus Sedan 1.8 Turbo 0 470 004 007 1.8 66 09/2000 - C9DC
    FORD Fiesta IV 1.8 TD 0 470 004 008 1.8 55 02/2000 - 12/2002 RTN
    FORD Fiesta IV1.8TD 0 470 004 008 1.8 55 02/2000-12/2002 RTP
    FORD Fiesta IV 1.8 TD 0 470 004 008 1.8 55 02/2000-12/2002 RTQ
    FORD Fiesta IV1.8TD Courier 0 470 004 008 1.8 55 02/2000-12/2002 RTN
    FORD Fiesta IV1.8TD Courier 0 470 004 008 1.8 55 02/2000-12/2002 RTP
    FORD Fiesta IV 1.8 TD Courier 0 470 004 008 1.8 55 02/2000-12/2002 RTQ
    FORD Focus I 1.8 TDDi 0 470 004 008 1.8 55 01/1999-05/2005 BHDA
    FORD Focus I 1.8 TDDi 0 470 004 008 1.8 55 01/1999-05/2005 BHDB
    FORD Focus I 1.8 TDDi 0 470 004 008 1.8 66 01/1999-05/2005 C9D...
    FORD Focus I 1.8 TDDi 0 470 004 008 1.8 66 01/1999-05/2005 C9DA
    FORD Focus I 1.8 TDDi 0 470 004 008 1.8 66 01/1999-05/2005 C9DC
    FORD Focus I 1.8 TDDi Turbo 0 470 004 008 1.8 55 08/1999-05/2005 BHDA
    FORD Focus I 1.8 TDDi Turbo 0 470 004 008 1.8 55 08/1999-05/2005 BHDB
    FORD Focus I 1.8 TDDi Turbo 0 470 004 008 1.8 66 01/1999-05/2005 C9DA
    FORD Focus I 1.8 TDDi Turbo 0 470 004 008 1.8 66 01/1999-05/2005 C9DB
    FORD Focus I 1.8 TDDi Turbo 0 470 004 008 1.8 66 01/1999-05/2005 C9DC
    FORD Transit Connect 1.8 0 470 004 008 1.8 55 05/2002 - BHPA
    FORD Transit Connect 1.8 0 470 004 008 1.8 55 05/2002 - BHPB
    FORD Transit Tourneo Connect 0 470 004 008 1.8 55 05/2002 - BHPA
    FORD Transit Tourneo Connect 0 470 004 008 1.8 55 05/2002 - BHPB
    FORD Transit Euroline 2.0 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 240 K/S 2 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 240 K/S 2 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 260 K/S 2 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 260 K/S 2 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 260 K/S 2 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 260 K/S 2 0 470 004 012 2.4 66 04/2001 - 04/2006 D2F...
    FORD Transit FT 280 K/S 2 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 280 K/S 2 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 280 K/S 2 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 280 K/S 2 0 470 004 012 2.4 66 04/2001 - 04/2006 D2F...
    FORD Transit FT 280 L 2.4 0 470 004 012 2.4 55 01/2000-09/2003 F4FA
    FORD Transit FT 280 L 2.4 0 470 004 012 2.4 66 01/2000 - 04/2006 D2F...
    FORD Transit FT 280 M 2.0 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 280 M 2.0 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 280 M 2.0 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 280 M 2.4 0 470 004 012 2.4 66 04/2001 - 04/2006 D2F...
    FORD Transit FT 300 K/S 2 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 300 K/S 2 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 300 K/S 2 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 300 L 2.0 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 300 L 2.0 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 300 L 2.0 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 300 M 2.0 0 470 004 012 2 55 08/2000 - 04/2006 D3FA
    FORD Transit FT 300 M 2.0 0 470 004 012 2 63 08/2000 - 04/2006 F3FA
    FORD Transit FT 300 M 2.0 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 330 K/S 2 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 330 K/S 2 0 470 004 012 2.4 55 01/2000-09/2003 F4FA
    FORD Transit FT 330 K/S 2 0 470 004 012 2.4 66 01/2000-04/2006 D2F...
    FORD Transit FT 330 L 2.0 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 330 L 2.4 0 470 004 012 2.4 55 01/2000-09/2003 F4FA
    FORD Transit FT 330 L 2.4 0 470 004 012 2.4 66 01/2000 - 04/2006 D2F...
    FORD Transit FT 330 M 2.0 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 330 M 2.4 0 470 004 012 2.4 55 01/2000-09/2003 F4FA
    FORD Transit FT 330 M 2.4 0 470 004 012 2.4 66 01/2000-04/2006 D2F...
    FORD Transit FT 350 EL 2. 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 350 EL 2. 0 470 004 012 2.4 55 01/2000 - 09/2003 F4FA
    FORD Transit FT 350 EL 2. 0 470 004 012 2.4 66 01/2000-04/2006 D2F...
    FORD Transit FT 350 L 2.0 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 350 L 2.4 0 470 004 012 2.4 55 01/2000-09/2003 F4FA
    FORD Transit FT 350 L 2.4 0 470 004 012 2.4 66 01/2000-04/2006 D2F...
    FORD Transit FT 350 M 2.0 0 470 004 012 2 74 08/2003 - 04/2006 ABFA
    FORD Transit FT 350 M 2.4 0 470 004 012 2.4 55 01/2000 - 09/2003 F4FA
    FORD Transit FT 350 M 2.4 0 470 004 012 2.4 66 01/2000 - 04/2006 D2F...
    FORD Transit FT 430 EL 2. 0 470 004 012 2.4 55 08/2002 - 09/2003 F4FA
    FORD Transit FT 430 EL 2. 0 470 004 012 2.4 66 08/2002 - 04/2006 D2F...
    FORD Transit FT 430 M 2.4 0 470 004 012 2.4 55 08/2002 - 09/2003 F4FA
    FORD Transit FT 430 M 2.4 0 470 004 012 2.4 66 08/2002 - 04/2006 D2F...
    FORD Transit Nugget2.0 T 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit Tourneo 2.0 0 470 004 012 2 74 08/2000 - 04/2006 ABFA
    FORD Transit FT 330 K/S 2 0 470 504 018 2.4 88 01/2000-04/2006 D4FA
    FORD Transit FT 330 K/S 2 0 470 504 018 2.4 92 01/2000 - 04/2006 DOFA
    FORD Transit FT 330 L 2.4 0 470 504 018 2.4 88 01/2000 - 04/2006 D4FA
    FORD Transit FT 330 L 2.4 0 470 504 018 2.4 92 01/2000-04/2006 DOFA
    FORD Transit FT 330 M 2.4 0 470 504 018 2.4 88 01/2000-04/2006 D4FA
    FORD Transit FT 330 M 2.4 0 470 504 018 2.4 92 01/2000 - 04/2006 DOFA
    FORD Transit FT 350 EL 2. 0 470 504 018 2.4 92 01/2000 - 04/2006 DOFA
    FORD Transit FT 350 L 2.4 0 470 504 018 2.4 88 01/2000 - 04/2006 D4FA
    FORD Transit FT 350 L 2.4 0 470 504 018 2.4 92 01/2000 - 04/2006 DOFA
    FORD Transit FT 350 M 2.4 0 470 504 018 2.4 88 01/2000 - 04/2006 D4FA
    FORD Transit FT 350 M 2.4 0 470 504 018 2.4 92 01/2000-04/2006 DOFA
    FORD Transit FT 430 EL 2. 0 470 504 018 2.4 92 08/2002 - 04/2006 DOFA
    FORD Mondeo III 2.0 TDDi 0 470 504 024 2 85 10/2000 - 08/2002 D6BA
    FORD Mondeo III 2.0 TDDi 0 470 504 024 2 85 10/2000- 08/2002 D6BA
    FORD Mondeo III 2.0 TDDi 0 470 504 036 2 85 10/2000- 08/2002 D6BA
    ISUZU KB 3.0 TDi 0 470 504 038 3 96 07/2002 -12/2004 4JH1
    ISUZU KB 3.0 TDi 0 470 504 038 3 96 07/2004 -11/2007 4JH1-TC
    MAN 10.145 L L2000 0 470 504 017 4.6 103 07/2001 - 06/2002 D 0834 LFL02
    MAN 8.185 L L2000 0 470 504 017 4.6 132 09/2000 - 08/2002 D 0834 LFL03
    MAN 8.185 LL L2000 0 470 504 017 4.6 132 09/2000 - 08/2002 D 0834 LFL03
    MAN 9.185 L L2000 0 470 504 017 4.6 132 09/2000 - 08/2002 D 0834 LFL03
    MAN Ale 0 470 504 017 4.6 02/2000-12/2001 D 0834 LOH01
    MAN LE 10.150 F, FL L2000 Evolution 0 470 504 017 4.6 110 06/2004 - 06/2005 D 0834 LFL04
    MAN LE 10.180 F, FA L2000 Evolution 0 470 504 017 4.6 132 09/2002 - D 0834 LFL03
    MAN LE 10.180 F, FL L2000 Evolution 0 470 504 017 4.6 132 09/2002 - 06/2005 D 0834 LFL03
    MAN LE 12.180 F, FL M2000L Evolution 0 470 504 017 4.6 132 09/2002- 12/2005 D 0834 LFL03
    MAN LE 140C F, FL L2000 Evolution 0 470 504 017 4.6 103 07/2001 - 08/2002 D 0834 LFL02
    MAN LE 1400 F, FL L2000 Evolution 0 470 504 017 4.6 103 07/2001 - 08/2002 D 0834 LFL02
    MAN LE 15.180 F, FL M2000L Evolution 0 470 504 017 4.6 132 09/2002 - 03/2005 D 0834 LFL03
    MAN LE 180B F, FL M2000L Evolution 0 470 504 017 4.6 132 07/2001 - 08/2002 D 0834 LFL03
    MAN LE 180C F, FA L2000 Evolution 0 470 504 017 4.6 132 07/2001 - 08/2002 D 0834 LFL03
    MAN LE 180C F, FL L2000 Evolution 0 470 504 017 4.6 132 09/2000 - 08/2002 D 0834 LFL03
    MAN LE 180C F, FL L2000 Evolution 0 470 504 017 4.6 132 07/2001 - 08/2002 D 0834 LFL03
    MAN LE 180C F, FL M2000L Evolution 0 470 504 017 4.6 132 07/2001 - 09/2002 D 0834 LFL03
    MAN LE 8.140 F, FL L2000 Evolution 0 470 504 017 4.6 103 09/2002 - 08/2004 D 0834 LFL02
    MAN LE 8.150 F, FL L2000 Evolution 0 470 504 017 4.6 110 06/2004-12/2005 D 0834 LFL04
    MAN LE 8.180 F, FL L2000 Evolution 0 470 504 017 4.6 132 09/2002-12/2005 D 0834 LFL03
    MAN LE 9.140 F, FL L2000 Evolution 0 470 504 017 4.6 103 09/2002 - 08/2004 D 0834 LFL02
    MAN LE 9.150 F, FL L2000 Evolution 0 470 504 017 4.6 110 06/2004 - 06/2005 D 0834 LFL04
    MAN LE 9.180 F, FL L2000 Evolution 0 470 504 017 4.6 132 09/2002 - 06/2005 D 0834 LFL03
    MG ZR 2.0 Turbodiesel 0 470 004 005 2 74 10/2001- 05/2005 TCie
    MG ZS 2.0 TD 0 470 004 005 2 74 10/2001- 05/2005 TCie
    MITSUBISHI Canter-35 3.0 Turbo 0 470 504 027 3 92 11/2000- 4M42
    MITSUBISHI Canter-35 3.0 Turbo 0 470 504 027 3 92 11/2000- 4M42-0AT
    MITSUBISHI Canter-55 3.0 Turbo 0 470 504 027 3 92 11/2000- 4M42-0AT
    NISSAN Almera 2.2 Diesel Turbo 0 470 504 012 2.2 81 01/2000- 02/2003 YD22DDT
    NISSAN Almera 2.2 Diesel Turbo 0 470 504 012 2.2 81 04/2000 - 03/2001 YD22DDT
    NISSAN Almera Tino 2.2 Diesel 0 470 504 012 2.2 81 05/2000 - 01/2003 YD22DDTI
    NISSAN Almera 2.2 Diesel Turbo 0 470 504 028 2.2 81 01/2000 - 02/2003 YD22DDT
    NISSAN Almera 2.2 Diesel Turbo 0 470 504 028 2.2 81 03/2001 - 02/2003 YD22DDT
    NISSAN Almera Tino 2.2 Diesel 0 470 504 028 2.2 81 05/2000 - 01/2003 YD22DDTI
    NISSAN Frontier ZD30 DD 0 470 504 029 3 78 11/2000- ZD30E
    NISSAN Frontier ZD30 DDT 0 470 504 038 3 112 11/2001 - ZD30ET
    NISSAN Patrol GR 3.0 Di 0 470 504 046 3 116 02/2000 - ZD30DDTI
    OPEL Astra G 1.7 DT 0 470 004 003 1.7 50 03/1998- 08/2000 X 17 DTL
    OPEL Astra G 1.7 DT Caravan 0 470 004 003 1.7 50 03/1998- 08/2000 X 17 DTL
    OPEL Vectra B 2.0 Dl 0 470 504 002 2 60 09/1996- 08/2000 X20 DTL 16VTurb
    OPEL Astra G 2.0 DT 0 470 504 003 2 60 03/1998- 08/2000 X 20 DTL
    OPEL Astra G 2.0 DT Caravan 0 470 504 003 2 60 03/1998- 08/2000 X 20 DTL
    OPEL Astra G 2.0 DTL 0 470 504 003 2 60 09/2000 - 01/2004 Y 20 DTL
    OPEL Astra G 2.0 DTL Caravan 0 470 504 003 2 60 09/2000 - 06/2004 Y 20 DTL
    OPEL Vectra B 2.0 Dl 0 470 504 003 2 60 09/1996- 08/2000 X20 DTL 16VTurb
    OPEL Zafira A 2.0 Dl 0 470 504 003 2 60 03/1999- 08/2000 X 20 DTL Turbo
    OPEL Vectra B 2.0 DTI 0 470 504 004 2 74 09/1997- 08/2003 X 20 DTH
    OPEL Frontera B 2.2 DTI 0 470 504 009 2.2 85 09/1998- 10/2002 X 22 DTH
    OPEL Frontera B 2.2 DTI 0 470 504 009 2.2 88 09/2002 - 09/2004 Y 22 DTH
    OPEL Omega B 2.0 DTI Turbo 0 470 504 009 2 74 09/1997- 08/2000 X 20 DTH
    OPEL Sintra 2.2 TD 0 470 504 009 2.2 85 09/1997- 09/1999 X 20 DTH
    OPEL Astra G 2.0 DT 0 470 504 011 2 60 03/1998- 08/2000 X 20 DTL
    OPEL Astra G 2.0 DT Caravan 0 470 504 011 2 60 03/1998- 08/2000 X 20 DTL
    OPEL Astra G 2.0 DTI 0 470 504 011 2 74 09/2000- 01/2004 Y 20 DTH
    OPEL Astra G 2.0 DTI Caravan 0 470 504 011 2 74 09/2000- 06/2004 Y 20 DTH
    OPEL Astra G 2.0 DTL 0 470 504 011 2 60 09/2000- 01/2004 Y 20 DTL
    OPEL Astra G 2.0 DTL Caravan 0 470 504 011 2 60 09/2000- 06/2004 Y 20 DTL
    OPEL Omega B 2.0 DTI Turbo 0 470 504 011 2 74 09/1997- 08/2000 X 20 DTH
    OPEL Vectra B 2.0 Dl 0 470 504 011 2 60 09/1996- 08/2000 X20 DTL 16VTurb
    OPEL Vectra B 2.0 DTI 0 470 504 011 2 74 09/1997- 08/2003 X 20 DTH
    OPEL Zafira A 2.0 Dl 0 470 504 011 2 60 03/1999- 08/2000 X 20 DTL Turbo
    OPEL Zafira A 2.0 DTI 0 470 504 011 2 74 04/1999- 07/2005 Y 20 DTH Turbo
    OPEL Astra G 2.0 DTI 0 470 504 015 2 74 09/2000-01/2004 Y 20 DTH
    OPEL Astra G 2.0 DTI Caravan 0 470 504 015 2 74 09/2000- 06/2004 Y 20 DTH
    OPEL Vectra B 2.0 DTI 0 470 504 015 2 74 09/2000- 09/2002 Y 20 DTH
    OPEL Zafira A 2.0 DTI 0 470 504 015 2 74 04/1999- 07/2005 Y 20 DTH Turbo
    OPEL Omega B 2.2 DTI 0 470 504 016 2.2 88 06/2000- 09/2003 Y 22 DTH Turbo
    OPEL Vectra B 2.2 DTI 0 470 504 016 2.2 92 09/2000- 09/2002 Y 22 DTR
    OPEL Astra G 2.2 DTI 0 470 504 209 2.2 92 09/2001 - 01/2004 Y 22 DTR
    OPEL Astra G 2.2 DTI Cabrio 0 470 504 209 2.2 92 03/2002 - 08/2005 Y 22 DTR
    OPEL Astra G 2.2 DTI Caravan 0 470 504 209 2.2 92 09/2001 - 06/2004 Y 22 DTR
    OPEL Astra G 2.2 DTI Coupe 0 470 504 209 2.2 92 03/2002 - 02/2005 Y 22 DTR
    OPEL Vectra C2.2 DTI 0 470 504 209 2.2 86-92 04/2002 - 09/2005 Y 22 DTR
    OPEL Vectra C 2.2 DTI Caravan 0 470 504 209 2.2 86-92 09/2003 - 09/2005 Y 22 DTR
    OPEL Zafira A 2.2 DTI 0 470 504 209 2.2 92 03/2002 - 07/2005 Y 22 DTR
    OPEL Astra G 2.0 DTI 0 470 504 218 2 74 09/2000 - 01/2004 Y 20 DTH
    OPEL Astra G 2.0 DTI Caravan 0 470 504 218 2 74 09/2000 - 06/2004 Y 20 DTH
    OPEL Zafira A 2.0 DTI 0 470 504 218 2 74 04/1999 - 07/2005 Y 20 DTH Turbo
    ROVER 220 2.0 SDI 0 470 004 005 2 77 09/1995 - 03/2000 20T2N
    ROVER 25 2.0 iDT 0 470 004 005 2 74 02/2000 - 05/2005 20 T2N-TCie
    ROVER 25 2.0 iDT 0 470 004 005 2 83 02/2003 - 05/2005 TCie
    ROVER 420 2.0 SDI 0 470 004 005 2 77 10/1995 - 03/2000 20T2N-TCie
    ROVER 45 2.0 iDT 0 470 004 005 2 74 02/2000 - 05/2005 20 T2N -TCie
    ROVER 45 2.0 iDT 0 470 004 005 2 83 02/2003 - 05/2005 TCie
    SAAB 9-3 2.2 16V Turbodiesel 0 470 504 004 2.2 85 03/1998- 10/2000 D223L
    SAAB 9-3 2.2 16V Turbodiesel 0 470 504 004 2.2 92 11/2000- 09/2002 D223L
    SAAB 9-3 2.2 Coupe 16V Turbo 0 470 504 004 2.2 92 11/2000- 09/2002 D223L
    SAAB 9-5 2.2TJD 0 470 504 208 2.2 88 03/2002 - D223L
    SAAB 9-5 2.2 TiD Kombi 0 470 504 208 2.2 88 03/2002 - D223L
    SKODA Superb 2.5 TDI 0 470 506 030 2.5 114 12/2001 - 08/2003 AYM
    VAUXHALL Astra G 1.7 DT 0 470 004 003 1.7 50 03/1998 -08/2000 X 17 DTL
    VAUXHALL Vectra B 2.0 DI 0 470 504 002 2 60 09/1996 - 08/2000 X20 DTL 16VTurbo
    VAUXHALL Astra G 2.0 DTL 0 470 504 003 2 60 03/1998- 08/2000 X 20 DTL
    VAUXHALL Astra G 2.0 DTL 0 470 504 003 2 60 09/2000 - 08/2005 Y 20 DTL
    VAUXHALL Vectra B 2.0 DI 0 470 504 003 2 60 09/1996- 08/2000 X20 DTL 16VTurbo
    VAUXHALL Zafira A 2.0 DI 0 470 504 003 2 60 03/1999- 08/2000 X 20 DTL
    VAUXHALL Vectra B 2.0 DTI 0 470 504 004 2 74 09/1997- 08/2000 X20 DTH 16VTurbo
    VAUXHALL Frontera B 2.2 DTI 0 470 504 009 2.2 85 09/1998- 09/2004 X 22 DTH
    VAUXHALL Frontera B 2.2 DTI 0 470 504 009 2.2 88 09/1998- 09/2004 Y 22 DTH
    VAUXHALL Omega B 2.0 DTI 0 470 504 009 2 74 09/1997- 08/2000 X 20 DTH Turbo
    VAUXHALL Sintra 2.2 TD 0 470 504 009 2.2 85 09/1997- 09/1999 X 22 DTH Turbo
    VAUXHALL Omega B 2.0 DTI 0 470 504 011 2 74 09/1997-08/2000 X 20 DTH Turbo
    VAUXHALL Vectra B 2.0 DI 0 470 504 011 2 60 09/1996-08/2000 X 22 DTH Turbo
    VAUXHALL Vectra B 2.0 DTI 0 470 504 011 2 74 09/1997-08/2000 X20 DTH 16VTurbo
    VAUXHALL Vectra B 2.0 DTI 0 470 504 015 2 74 09/2000-08/2001 Y20 DTH 16VTurbo
    VAUXHALL Omega B 2.2 DTI 0 470 504 016 2.2 88 06/2000-09/2003 Y 22 DTH Turbo
    VAUXHALL Vectra B 2.2 DTI 0 470 504 016 2.2 92 09/2000-08/2001 Y 22 DTR Turbo
    VAUXHALL Astra G 2.2 DTI 0 470 504 209 2.2 92 09/2001-08/2005 Y 22 DTR
    VAUXHALL Vectra C 2.2 DTI 0 470 504 209 2.2 86-92 04/2002-09/2005 Y 22 DTR
    VAUXHALL Vectra C 2.2 DTI Estat 0 470 504 209 2.2 86-92 09/2003-09/2005 Y 22 DTR
    VAUXHALL Zafira A 2.2 DTI 0 470 504 209 2.2 92 03/2002-06/2005 Y 22 DTR
    VOLKSWAGEN Passat 2.5 TDI 0 470 506 002 2.5 110 08/1998-11/2000 AFB
    VOLKSWAGEN Passat 2.5 TDI Syncro 0 470 506 002 2.5 110 08/1998-11/2000 AFB
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 002 2.5 110 08/1998- 11/2000 AFB
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 002 2.5 110 02/1999- 11/2000 AFB
    VOLKSWAGEN Passat 2.5 TDI 0 470 506 006 2.5 110 08/1998- 11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI 0 470 506 006 2.5 110 10/2000-05/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI 4 Motion 0 470 506 006 2.5 110 10/2000-01/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI Syncro 0 470 506 006 2.5 110 08/1998- 11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 006 2.5 110 05/1999- 11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 006 2.5 110 10/2000-05/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 006 2.5 110 10/2000-01/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI 0 470 506 010 2.5 110 08/1998- 11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI 0 470 506 010 2.5 110 10/2000-05/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI 4 Motion 0 470 506 010 2.5 110 10/2000-01/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI Syncro 0 470 506 010 2.5 110 08/1998-11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 010 2.5 110 05/1999-11/2000 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 010 2.5 110 10/2000-05/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI Variant 0 470 506 010 2.5 110 10/2000-01/2003 AKN
    VOLKSWAGEN Passat 2.5 TDI 4 Motion 0 470 506 033 2.5 132 01/2003-05/2005 BAU
    VOLKSWAGEN Passat 2.5 TDI 4 Variant 0 470 506 033 2.5 132 01/2003-05/2005 BAU
    VOLVO FL6 180 0 470 506 017 5.5 132 05/2000 - D6B180
    VOLVO FL 6 220 0 470 506 017 5.5 162 05/2000 - D6B220
    VOLVO FL 6 250 0 470 506 017 5.5 184 05/2000 - D6B250
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    well done i have never heard of anyone doing a diy job on a vp44 , have you any pics of where the location of the sensor is on the pump
    this is 1 for the how 2
    Dec 2012
    Worthing
    Quote Originally Posted by peadar View Post
    Thanks job is actually easier than it looks like, no special knowledge required.
    I do have some more pictures of pump disassemble and other way around (pumps ecu, actual pump stays in a car). I will add some more info tomorrow or Monday then.
  1. Replies: 2
    Last Post: 24th June 2012, 02:11
  2. Camshaft position sensor
    By disco dan in forum Engine & Drivetrain
    Last Post: 16th November 2011, 18:29
  3. camshaft sensor
    By lusk in forum Engine & Drivetrain
    Last Post: 6th March 2011, 19:30
  4. plz help,P0340 Camshaft Position Sensor Circuit Malfunction
    By bedo13 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2010, 14:58
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
https:www.vectra-c.comforumshowthread.php178716-Y22dth-po340-camshaft-position-sensor-malfunction
p0340 opel zafira 2.2 dti
opel zafira 2.2 dti p0340
Opel DTC P0340-fa
y22dtr cam sensor location
vauxhall p0340--002
Opel P0340--008
opel zafira 2.2 dti camshaft sensor
eroare p0340 y20dth
p0340 opel vectra c 2.2dti
p0340 opel zafira
vectra c cam shaft malfunction
opel zafira 2.2dti P0340 senzor pompa
zafira 2.0 dti camshaft sensor location
зафира 2.2дизель ошибка p0340
po340 opel vectra
OPEL P0340(008)
vectra c camshaft position sensor
crank position sensor y22dtrvehicle speed sensor opel sintra 1998vauxhall vectra 2.2 2005 cam shaft sensoropel zafira 2005 2.2 camshaft sensor location forumCamshaft Position Sensor Circuit Malfunction vp44PO340-008 Camshaft
