Thread: still misfire
    Apr 2009
    berkshire
    Default still misfire
    hi all changed coil pack this morning still misses on idle ,although does rev a bit smother,wondering could it be afm next ? unplugged the plug and its a bit sticky with like oil ,can the afm be cleaned or does it mean new one .Any ideas on misfire pls.p.s i have not had codes cleared yet would that make a difference thanks alan
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What car and engine mate ??
    Apr 2009
    berkshire
    sorry its 02 vec c 1.8 manual
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Runn the car with it runnint if you unplug the maf and it doesnt do out its ya maf mateb
    Apr 2009
    berkshire
    so if i unplug it should it cut out or something along those lines then
    Apr 2009
    berkshire
    ok no different with it unplugged what now ?????
    Apr 2009
    berkshire
    Aug 2011
    Bristol
    Have you checked spark plugs??
    I have a misfire in 1 and 4 but before changing I need to check for spark in the coils to confirm. Mine only comes when it hits 3000rpm but fine when stood still and reved.
    If the coil is fine I am in same situ so watching this.
    I need to check plugs but they should be fine as new 4 months ago and Denso Iradium.
    Hope you get there.
    Apr 2009
    berkshire
    no should have done them when had top off ,but thought it cant be simple as plugs in my case lol
    Regular Member wingi's Avatar
    Dec 2012
    clipstone
    i would check your breather pipes i have had a couple of ecotecs that only miss under load and found crank breather pipes blocked cleaned out and all is grand worth a look, and cheap fix if it works lol
  1. misfire on 1.8
    By Lozza in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:57
  2. misfire?
    By ivesy in forum Engine & Drivetrain
    Last Post: 11th February 2011, 19:55
  3. V6 misfire?
    By lencuff in forum Engine & Drivetrain
    Last Post: 16th November 2010, 21:10
  4. 1.8 misfire
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:09
  5. Misfire
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2006, 16:30
