Results 1 to 10 of 16
Thread: Stiff gearchange
    Regular Member monkeybusiness's Avatar
    Wirral Merseyside
    Default Stiff gearchange
    Im sure I've seen a thread on here before regarding this problem. Sometimes, the gears are stiff and notchy to change on my Vectra. Anyone know the reason why? As far as Im aware the clutch is ok
    either the gearchange needs lubing, the cables are wearing, or the linkage is out of alignment.....
    needs a dealer trip mate....
    Wirral Merseyside
    Dealer trip??? I'll put up with it first!
    well, the 1st thing you could try is spray grease on the linkages.. see if that will free anything off...
    is it blocking any gears yet, or just V stiff??..
    Wirral Merseyside
    To be honest, its not excessively stiff. Just sometimes, maybe more when cold. I can certainly live with it, just thought someone else may have had the problem and there was a "quick fix"
    I'll try lubing the cables, thanks
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Hmmm I seem to remember a Vauxhall technical document around stiff gear changes when cold ... I'll have a scout around TIS if I get chance later
    Jul 2006
    Cheshire
    I think this is the one I'm thinking of:
    Field Remedy: 1653
    Subject:
    F23 transmission - Bad cold shifting behaviour in 1st and 2nd gear
    Models:
    Astra-G 1998 ... 2004,Zafira
    1999 2004,Speedster 2001 ... 2004,VX220
    2001 2004,Vectra-B 1998 2004,Vectra-C
    2002 2004,Signum 2003 2004
    Engines:
    AII,AII,AII,AII,AII,AII ,All
    Option:
    F23 Transmission
    Complaint:
    Some customer complain about bad cold shifting behaviour in 1 st and 2nd gear. The gearshift mechanism is correctly adjusted and clutch system is bleeded.
    Cause:
    Tolerances of toothing of the sliding gear.
    Production:
    Introduction of transmission with modified siding gear as of transmission number Gxx03240969 in calendar week 41 /2003.
    Remedy:
    In case of customer complaint the sliding gear has to be replaced by using the Repair Kit, Partno.: 9201451 / Catalogno.: 16 07 013. There is no need to replace the entire transmission.
    FunctionalGroup:
    K - Clutch/Transmission
    Complaint Group:
    08 - Hard to operate
    Trouble Code:
    None
    Wirral Merseyside
    Hey thats great tech info. Mmm, looks like its an inherent problem. Think I will stick with it for now. Only happens now and again.
    Thanks for the info..........MB
    Surely yours is the F18 box,not the F23?
    Jul 2006
    Cheshire
    Quote Originally Posted by prm View Post
    Why do you say that Prm?
    Dave
  1. 2003 2.2DTi Stiff gearchange when engine hot.
    By Mogsy007 in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 21:39
  2. automatic gearchange
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 22:54
  3. Gearchange linkage
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 21:07
  4. Gearchange- what to check first?
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 13th November 2008, 20:59
  5. Notchy Gearchange
    By BigP in forum Engine & Drivetrain
    Last Post: 1st February 2007, 20:11
2004 vectra c 2.2 f23 gearbox stiff gear change
vauxhall insignia stiff gear change
