Thread: Vectra 2.2 DTI SRI Starting Problems
    Oct 2012
    Nottinghamshire
    Default Vectra 2.2 DTI SRI Starting Problems
    Hi guys,
    This is my first post, but I have been lurking around for quite a while and found the forums very informative
    Anyway I seem to have a slight issue with my Vectra 2.2 DTI, a bit of a long story but here we go:
    A couple of months back the wife managed to top up a half full tank od diesel with £20 worth of petrol, not realising she then drove almost 200 miles home without noticing.
    The next day it took ages to get started so I decided to call out the AA. found the petrol and advised to have it drained.
    The next day I called my mechanic who advised to get the car going, burn off as much fuel as possible then brim it with Diesel and all should be ok.
    Luckily all seemed to be fine after, but lately I have had issues when the car is parked on an incline (facing uphill) it struggles to start.
    Could this be related to the petrol incident? or just coincidence? any ideas of what it could be?
    finally is there anything that should be replaced following the mix up.... fuel filters etc.?
    Alex
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    sounds like a leak off pipe or injector seal problem .
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Quote Originally Posted by DTi Elite View Post
    leak off pipes sound about right or check the fuel filter housing for splits
    did you change the filter after the petrol incident if so did you changes the seals
    Oct 2012
    Nottinghamshire
    in all fairness nothing has been changed yet, Ive been meaning to get back in touch with my mechanic but with lots of things going off with christmas ive not got round to it yet, What things are a good idea to change out after having petrol in the tank??
  1. Vectra 1.9cdti starting problems
    By Dale1 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 14:29
  2. Vectra 2.0 dti Starting problems
    By willias233 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 20:06
  3. My Vectra C 2003 DTI cold starting problems solved hopefully
    By jameso in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2011, 15:18
  4. starting problems 2004 vectra 1.9 deisel
    By higgy7511 in forum Engine & Drivetrain
    Last Post: 25th October 2010, 00:39
  5. Vectra 2.0 dti starting problems
    By daveymaboy in forum Engine & Drivetrain
    Last Post: 31st March 2009, 15:43
