Results 1 to 10 of 13
Thread: Coolant
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default Coolant
    The last thing i need to do to the car for now is change the coolant as it is looking a little dirty but what coolant should i use? Should i get the red coolant from vaux or halfords coolant which i have used on my other cars for years which have been fine
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Price it at VX first imo.
    11 Post(s)
    Vx's 'own' brand coolant will be fine.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Yup, just finish this myself today after a thermostat change... DexCool from VX is what I found 20 quid for 5 litres or so. Actually it might be cheaper.
    Matt
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    5 litres of Vx coolant on eBay for £20 delivered think I will get that
    Feb 2012
    Calne UK
    That's the stuff, it arrived next day.
    It's an easy job this, just make sure you car is flat and level before you start, and your cooling system holds about the 5 Litres. (though I've got a bit left over.)
    Worth doing a flush whilst you're there too....
    Matt
    11 Post(s)
    Quote Originally Posted by jamiedvvt View Post
    Last time I looked, it was only something like £15 or £16 at the dealers.
    If your system holds 5 litres (as VVT-i-Matt suggests) then drain out the old, flush the system through with plain water, then pour in 2½ litres of neat coolant, and finally top up with water. That way you'll get as close to a 50/50 mix as you can get (because, no matter how hard you try, there will always be some water remaining in the system after draining/flushing)
    durham
    Trim : Leather
    I don't suppose anyone's done this on their 3.0ltr v6 cdti have they? Mines an 05 with 70 k on and think its time it was done any advice peeps? Cheers.
    11 Post(s)
    Pretty much the same way as the HOW2 I would imagine.
    I would have thought all the radiators (regardless of engine size) have the drain tap on the lower offside of the car.
    durham
    Trim : Leather
    Cheers dave
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
