Results 1 to 2 of 2
Thread: dashboard and gear lever
    Aug 2011
    Bristol
    Default dashboard and gear lever
    How do I take the center console apart??
    I want to get down to the cigarette lighter and gear linkage and have tried many times but can't even get 1 piece out.
    I presume I have to pull a certain 1 out first to get to bolts for others?
    Presume they are all the same but 2.2 direct if not
    Feb 2011
    Selby
    Pull on the gearstick gaiter surround - it just unclips. The cubby hole also unclips and pulls out. Now you can remove the ashtray, again it just unclips. Undo it's wiring plug and remove (if you have an illuminated ashtray that is). The bit with the cig lighter socket on also just unclips and comes out. You can also pop out the cupholder/tray bit too. No screws anywhere...
    I've fed my phone charger cable from the cig lighter socket down the back under the cubbyhole, then back under the gearstick (taped to the side out of the way of the lever itself) then up at the back of the gaiter surround so the plug rests neatly in the cupholder.
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. dodgy gear lever
    By clightowler in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2010, 11:39
  3. VXR Gear lever
    By Derek Mc in forum Styling
    Last Post: 2nd June 2010, 20:19
