Results 1 to 10 of 26
Thread: Gear link or box issue
    Aug 2011
    Bristol
    Default Gear link or box issue
    Been about a week now and have just figured the issue just need a soloution.
    Mt gear stick does not return to centre.
    I have noticed it was difficult at first to get into 3rd frm 5th or 4th and kept ending up in 5th, or 2nd to 5th.
    Now I understand why because I would just push it up and it was not in the correct place.
    Is this just linkege/spring or something like that or gearbox issues??
    Regular Member paulmac's Avatar
    Slough
    9 Post(s)
    This happened to me last week, if you look under your battery tray area you should see 2 cables that attached to the top of the gear box, you will hopefully see that the cable sits in a like half moon shape, if like mine all that's happened it that it's fallen out of the half moon.
    It's really hard to explain but what your describing is exactly what mine was like.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by GCusdin View Post
    I have a spare gear knob selector tray here if it needs replacing
    Aug 2011
    Bristol
    will look tomorrow.
    Do you have a photo paulmac??
    I sort of understand but want to know what it should look like.
    The pump was changed 2 weeks ago so may have been knocked out or something
    You never know C-Owner, may do. Thanks for the offer and will let you know
    Slough
    9 Post(s)
    Hopefully this will work.
    Slough
    9 Post(s)
    you need to find both those cable and follow them back, they should BOTH be fixed in position and not loose.
    If you get stuck PM me your number.
    NOTE, this is for the F40 box.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    The mac has returned
    Slough
    9 Post(s)
    Evening Chris,
    You alright???
    I'm pretty sure this is exactly the same as what happenend to me last week when I went to see Khalid, luckily only took 10 mins to sort out lol
    Aug 2011
    Bristol
    Thanks mac.
    Had a little look but not enough light and time now. Will look tomorrow and update
    Are you VXR Enough
    13 Post(s)
    Hi ya bud all good thanks. you? still no warning lights?
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. 1st gear issue
    By redmans in forum Engine & Drivetrain
    Last Post: 4th December 2012, 15:04
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Replies: 4
    Last Post: 11th November 2011, 12:05
  5. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
