Thread: Heaters not working
    Apr 2011
    Berkshire
    Default Heaters not working
    My heaters in my car aren't working on any setting, I have fitted a new pollen filter, the motor itself spins freely when I try to turn it with my hand.
    I have also replaced the resistor and it still isn't working, has anyone got any ideas on what it could be?
    When I turn the heaters on I don't get any clicking from the fusebox it the foot well till I get it to setting 4.
    Any thoughts would be great
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Did you replace just the resistor or the resistor pack? It could be the blue relay as this also controls the fan speed for 1,2&3.
    Apr 2011
    Berkshire
    I replaced the resistor pack
    I went to vauxhall to get a blue relay and they said they never stocked them where is best to get one?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Resistor faulty?
    Control dials not working properly?
    Wirings loose or corroded at fan.
    Does heating work hot and cold? If not working properly, refer to red lever motor servo, if working fine, flush the heater matrix accessed from engine bay.
    Does fan stop fanning when on 0 position? If it goes on at 1 then not wiring or dials. And will lead to failing resistor. Its fragile so handle it with care when fitting.
    Apr 2011
    Berkshire
    It used to work on just setting 4 then stopped working all together, I bought the resistor pack from vauxhall so shouldn't be faulty but will buy a new resistor tomorrow and try.
    You still get a little bit of heat through it just doesn't blow it through!
    The red lever mottor for the temperature works fine.
    I get a clicking when turning the fan from 0-1 then a click from 3-4 but not on the others
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. HELPP!! Heaters not working
    By vectrasri-j in forum Bodywork & Interior
    Last Post: 25th December 2011, 21:59
  3. Heaters
    By Bazz in forum Bodywork & Interior
    Last Post: 2nd December 2011, 23:45
  4. heaters
    By gary hough in forum Bodywork & Interior
    Last Post: 3rd September 2011, 12:38
  5. heaters not working on signum
    By superjetandy in forum Vectra C / Signum Troubleshooting
    Last Post: 1st March 2011, 17:08
vauxhall signum heaters arent working
