Thread: Heater / Blower Not Working Properly (2006 Vectra 1.8)
    Regular Member bigboynigs's Avatar
    Oct 2007
    ALDERSHOT
    Default Heater / Blower Not Working Properly (2006 Vectra 1.8)
    Hi all, I have a 2006 Vectra Exclusiv which up until the other day was fine, now the blower has decided to go either all or nothing i.e. 1,2 & 3 setting nothing happens but full blast on 4 it is fine.
    Everything else works fine, temperature, changing of direction of blowers from screen to floor etc. Not really very electrically minded so help appreciated.
    Bit of a pain in the **** having to turn fan on as fogging up, turn it off as sweating too much, on again as fogging.........etc, etc
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like your heater motor resistor has gone fella theres tons of threads on here about it the search box is your friend
    also make sure your scuttle panel drains are clear again lots of threads about that too
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Could also be the blue relay (this controls speed 1,2 & 3) behind the glovebox.
    West
    as already said... due to the scuttle drain being blocked it will have filled with water & found it's way down passed the pollen filter onto the heater resistor pack... remove/replace pollen filter (my guess is it's wet) clear scuttle drain or just remove the bung altogether & replace resistor
  1. Heater Fan Blower. Vectra C
    By Milden in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 20:22
  2. Heater Blower not working on Climate Control Model
    By wifesgotasignum in forum Vectra C / Signum Troubleshooting
    Last Post: 14th June 2012, 09:54
  3. wanted heater blower motor vauxall vectra c
    By Les45 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 08:21
  4. Heater blower stopped working
    By owb82 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2009, 18:24
  5. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
